Block heater Plug cover?
/ Block heater Plug cover? #1
Cliff_Johns
Elite Member
Northern Illinois
JD 4110
The block heater plug on my JD4110 just hangs down by the side of the engine. Do people usually put something on it to keep it from caroding -- I was thinking of using a old extension cord female plug end and keeping it pluged into that -- like a tail, but then I thought that might make it worse if water did get into it.
Thoughts?
Cliff
/ Block heater Plug cover? #2
That is basically what I did. I took a 2 prong male to 3 prong female adapter and plugged it into the block heater connector cord. I also cut off the male prongs from the adapter.
/ Block heater Plug cover? #3
I like Mad's idea /forums/images/graemlins/grin.gif they cost all of about 29 cents
Not much moisture will work its way in, and if you're worried it will, smear some grease or Vaseline on the plug before you plug it in.
</font><font color="blue" class="small">( Not much moisture will work its way in, and if you're worried it will, smear some grease or Vaseline on the plug before you plug it in. )</font>
As long as the grease isn't conductive. I'm not sure I've seen that on the label.
Cliff
/ Block heater Plug cover? #5
But with just an adapter plugged on to keep it clean and dry, no need to worry about conductivity
/ Block heater Plug cover? #6
On my tractor there is a female cover that it came with. On my truck I installed an onboard marine charging recepticle into the bumper. All it is is a male plug that mounts in a cut hole in the bumper, complete with cover. Go to a boat store and make sure you ask for an onboard charging recepticle if you want a clean & easy to use way to plug in.
</font><font color="blue" class="small">( But with just an adapter plugged on to keep it clean and dry, no need to worry about conductivity )</font>
I was thinking that when you unplugged the adapter, and plugged it into an outlet, residual conductive grease might cause a ... uh ... surprise.
Cliff
/ Block heater Plug cover? #9
Is there any reason not to just unplug the cord at the heater? I removed mine last year, and now again for this summer. Should I be concerned about corrosion on those terminals?
/ Block heater Plug cover? #10
I don't know if I'd remove it at the heater. I just do like the others - put a female plug on the end, wrap it in electrical tape, and connect it to something via an electrical tie so it doesn't jangle around.
-Bob
2016 Nissan Titan XD Crew Cab Pickup Truck (A61573)
2016 Nissan Titan...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
GENERAC MOBILE...
2005 Sterling Cab (A66736)
2005 Sterling Cab...
SHORTWOOD 5 BOLTSTER LOG TRAILER (A64276)
SHORTWOOD 5...
PALLET OF FLANGE CUT-OFF VALVES (A67714)
PALLET OF FLANGE...
Generator Inverter (A64553)
Generator Inverter...
