Block Heater on a BX 24
   / Block Heater on a BX 24 #1
whatever1
Earth
When it gets cold enough to use the block heater is there any harm to leaving it plugged in all the time or should I just plug it in just before I am going to start the tractor.
   / Block Heater on a BX 24 #2
You'll burn the element out quick if you leave it on, not to mention use a lot of electricity unnecessarily. 15 or 20 minutes on a cold day and my engine is toasty warm.
   / Block Heater on a BX 24 #3
A timer is a good thing to use with a block heater. I told my kid to unplug the block heater one day and he wandered off towards the shed. I looked 10 days later and the block heater was still plugged in running up my power bill 24/7.
darn fool kid just could not understand why I was upset.
   / Block Heater on a BX 24 #4
I use a heavy duty timer. Actually bought the 2 pack last year, 1 for truck and 1 for BX. Worked great. The pins kind of sucked, pretty much set and leave alone. Used 2 different times for the BX, before and after work.
Amazon.com: Intermatic TN311 15 Amp Heavy Duty Grounded Timer - 2-Pack: Home Improvement
I think the heater is 400 watts. I dont know about being toasty warm in 15 minutes but I'll time it for 1 hour before using it.
   / Block Heater on a BX 24 #5
I've got remote switches for both of my block heaters. The original GE switches quit working so I just bought 2 more from Home Hardware up here. They are made by woods.
I go to the kitchen window and click on the switch and the block heater comes on. I have a short string of LED christmas lights T'ed off of the line going to the heaters so I know for sure they are on. Lights are on....heaters are on.
Home Hardware - Remote Contol for Outdoor Lights and Decorations
   / Block Heater on a BX 24 #6
I should have noted that 15-20 minutes was what it takes for my block heater to get the engine warm, but it will depend on your tractor and the weather. I have a small 18 HP engine and live in KY where really cold temps are rare. If you have a larger tractor and live in a place with more extreme weather you'll, of course, need more time.
I'd recommend trial and error to find the correct amount of time needed.
Jeff
   / Block Heater on a BX 24 #7
If a storm is expected or I know that I will be using the tractor the next day i plug mine in the night before. The small amount of electricty used won't even be noticed on my electric bill and I know it is warm and ready to go.
   / Block Heater on a BX 24 #8
I plan to get a wemo outlet. I can then turn it on before I leave work, if needed.
Granted, requires some technical expertise, but mostly just needs wifi.
2007 JLG E400AJP TELESCOPIC/SCISSORING MANLIFT (A52709)
2007 JLG E400AJP...
Redirective Crash Cushion Guardrail (A59230)
Redirective Crash...
CATERPILLAR 416C BACKHOE (A60429)
CATERPILLAR 416C...
2003 UTILITY TRAILER MANUFACTURER UTILITY TRAILER MANUFACTURER (A55745)
2003 UTILITY...
1969 Lincoln Continental Mark III (A56857)
1969 Lincoln...
2019 Ford F-350 4x4 Crew Cab Pickup Truck (A59230)
2019 Ford F-350...
