Block heater location?
/ Block heater location? #21
I see Kevin beat me to it. Mine is in the exact same position as his in relation to the radiator (the BX is a reverse airflow design), and looks just like his. The plug in the engine screwed out and the Heater screwed in...all there was to it....
/ Block heater location? #22
Scott:I appreciate your reply and insight./w3tcompact/icons/wink.gif and Kevin for the great photos /w3tcompact/icons/clever.gif. Did you have any signifigant loss of coolant when you removed the 17 mm plug? ....RayBee
/ Block heater location? #23
As an afterthought, since Kevin so nicely documented the Block heater installation, I'm including a before pic. of the plug on a 2710. /w3tcompact/icons/wink.gif..RayBee
/ Block heater location? #24
And another showing the 17mm socket used to remove the plug. ...RayBee /w3tcompact/icons/smile.gif
/ Block heater location? #25
I have no idea if they lost fluid. This was a dealer install. They don't ship them out without a block heater in our neck of the woods /w3tcompact/icons/wink.gif.
Kevin
Guys,
I can't thank you all enough for taking the time to help. I noticed in all your pictures that the hose kubota is suggesting I remove and plug, has been relocated to below the heater. I can only guess that this means the designer thought the hose serves a useful function or they would not have keep it on your newer machines.
I think I'm going to try to find a heater that fits a freeze plug or just go back to using my heat lamps to keep the machine warmer.
Thanks again all...
/ Block heater location? #27
buzst:I noticed from your profile that you're from NH. I bought my 2710 from Chappell's in Milford and found them to be helpful with my questions. You might try their knowledge base. /w3tcompact/icons/wink.gif ..RayBee
/ Block heater location? #28
Raybee,
I just installed a block heater in my JD4110. Detail listed under "Parts/Repairs" . I did have about 1 qt. of coolant come out of the block after removing the plug. I would suggest draining the radaitor (to release pressure) before hand otherwise you will get squirted with collant. Plugged the heater in for about 4 hrs to test it. Motor was warm to the touch and she started just like it was summertime. Good Luck with it ....
Mark
/ Block heater location? #29
Mark,Many thanks for sharing your installation details with me and fellow TBN subscribers. /w3tcompact/icons/wink.gif Your website instructions and overview were very detailed and clear. /w3tcompact/icons/clever.gif You have cleared any remaining doubts about the installation and what it entails. /w3tcompact/icons/cool.gif ..RayBee /w3tcompact/icons/smile.gif /w3tcompact/icons/smile.gif
2015 Hyundai Genesis 3.8 Coupe (A61574)
2015 Hyundai...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
Valley Model 8000 Irrigation System (A62180)
Valley Model 8000...
2013 Ford F-150 Crew Cab Pickup Truck (A61573)
2013 Ford F-150...
2018 Navigator RT-6500 6,500lb Piggyback Forklift (A61567)
2018 Navigator...
2 Row Cultivator (A64047)
2 Row Cultivator...
