Block heater location L 2501
/ Block heater location L 2501 #1
24mph
Shiawassee County ,MI
John Deere MT, Kubota 2501
I purchased a screw-in block heater manufactured by Kats for a 2016 L2501 Kubota. I cannot figure out where it goes. Am I blind or is the 2016 engine redesigned and Kats hasn't realized it yet ?
/ Block heater location L 2501 #2
I don't know for sure so take this with a gain of salt. These standard L's uses the frost plugs. You remove one and insert the threaded part... DO NOT drill it out, there's a thread about someone having to re-build his block.
Does it look like this:
/ Block heater location L 2501 #3
Teg is correct. The element is a soft plug type application. Order the part from your Kubota dealer.
I didn't get the large replacement for the frost plug, only the threaded element. Will check with the supplier. I didn't buy it from a Kubota dealer.
/ Block heater location L 2501 #5
The cylinder walls are very close to the softplugs so the nipple is required for the element to have room for install.
2016 BOBCAT E35I EXCAVATOR (A60429)
2016 BOBCAT E35I...
2019 Ram 4500 4x4 S/A Dump Truck (A59230)
2019 Ram 4500 4x4...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
UNUSED 7" MINI EXCAVATOR TOOTHBED BUCKET (A60432)
UNUSED 7" MINI...
20FT X 30FT STEEL CARPORT (A58214)
20FT X 30FT STEEL...
2019 JOHN DEERE 325G SKID STEER (A60429)
2019 JOHN DEERE...
