Block Heater Location, BX 2200??
   / Block Heater Location, BX 2200?? #12
Try one of the major auto supply stores. Around here, AutoZone is one of the big ones. They usually have all kinds of odd-ball sized tools for car parts. If I remember correctly, the 17mm is a pretty common size for cars. Most of the places have a "borrow" (if you buy parts needing the tool) or rental for them. Worst case, they usually are excessively priced.
Kevin
   / Block Heater Location, BX 2200?? #14
Tom: ...The 17mm socket is a 3/8" drive and was purchased about 10
yrs. ago to drain a tranny on a VW beetle. I believe I got it at Sears? or
in (metric tool section- $5/$7) of an auto parts store. I mentioned in an earlier post to get a 1/2" drive or
it will break. If you look closely at the last pix, you'll see where the socket
had to be welded to the (3/8" to 1/2") adapter because it was about to
break off the 3/8" drive shank. Otherwise if you can locate a 1/2" drive
17mm socket you are good to go. /forums/images/graemlins/smile.gif RayBee
   / Block Heater Location, BX 2200?? #15
Grainger has one made by Proto (Stanley) for $13.86 catalog price.
   / Block Heater Location, BX 2200?? #17
My Tool Store has one for under $9 made by S-K
So they should be available in a few locations if Proto and S-K make them.
   / Block Heater Location, BX 2200?? #18
Tom,
Around here anyone can buy from Grainger. But if you are a business you can get a better price. I own a HVAC business and we get around a 25% better price. Doesn't come out to much on a tool that runs around ten or fifteen bucks.
Murph
   / Block Heater Location, BX 2200?? #20
I just stopped by my Kubota dealer to order a block heater for my BX2200. One of the mechanics showed me where the plug was located. He said that he recomends using a short bolt with two nuts locked on the end to get the plug out. He said that will save me from buying a allen socket that I will only use once. I plan to give it a try. He didn't know what size of bolt. A bolt and two nuts should be cheaper that a allen socket.
John
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A55315)
2012 UNVERFERTH...
2017 John Deere 6120E (A53317)
2017 John Deere...
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A56857)
2020 Caterpillar...
2024 CASE TV620B SKID STEER (A52709)
2024 CASE TV620B...
8 Piece Mini Excavator Heavy Duty Attachment Set (New/Unused) (A59225)
8 Piece Mini...
2011 NEW HOLLAND C227 SKID STEER (A52709)
2011 NEW HOLLAND...
