Block Heater Installation Instructions
/ Block Heater Installation Instructions #22
You drain down your coolant.
Take a screw driver poke a hole in the soft plug right in front of the starter on the driver side pull that out.
Clean the hole out we usually put a rag there to soak up the antifreeze.
Take the drive in insert put a bead of loc-tite around it, I use a impact socket and a long extension and I drive the insert in gently.
I apply Teflon tape to the element threads, screw it in and snug it up.
I then take soapy water and lube the nut that holds the 110 wire on and tighten that up.
I put the soapy water on so when I tighten it up it doesn't try to rotate the Cord.
Then pour the antifreeze back in.
It takes about a 1/2 hour.
It's just a tiedius job.
Thanks Rick!
2007 CHEVROLET 3500 DUALLY 4X4 DIESEL TRUCK (A59575)
2007 CHEVROLET...
203201 (A60429)
203201 (A60429)
Snap-On Zeus Diagnostic Machine (A61307)
Snap-On Zeus...
2014 Timpte Hopper Bottom (A61307)
2014 Timpte Hopper...
1985 CADILLAC SEVILLE (A60736)
1985 CADILLAC...
PJ  32 FLATBED GOOSENECK (A58214)
PJ 32 FLATBED...
