Block Heater Installation Instructions
/ Block Heater Installation Instructions #22
You drain down your coolant.
Take a screw driver poke a hole in the soft plug right in front of the starter on the driver side pull that out.
Clean the hole out we usually put a rag there to soak up the antifreeze.
Take the drive in insert put a bead of loc-tite around it, I use a impact socket and a long extension and I drive the insert in gently.
I apply Teflon tape to the element threads, screw it in and snug it up.
I then take soapy water and lube the nut that holds the 110 wire on and tighten that up.
I put the soapy water on so when I tighten it up it doesn't try to rotate the Cord.
Then pour the antifreeze back in.
It takes about a 1/2 hour.
It's just a tiedius job.
Thanks Rick!
Lincoln SAE-400 Shield-Arc DC Arc Welder - Inoperable (A63689)
Lincoln SAE-400...
2015 CATERPILLAR 299D2 SKID STEER (A64279)
2015 CATERPILLAR...
2001 KENWORTH W900 72" STUDIO SLEEPER (A62613)
2001 KENWORTH W900...
2016 Volvo VNL T/A Sleeper Cab Truck Tractor (A61573)
2016 Volvo VNL T/A...
2016 Deere 180G (A60462)
2016 Deere 180G...
2015 Hagie STS 12 Sprayer (A63111)
2015 Hagie STS 12...
