Blew my zerk?
/ Blew my zerk? #1
C4Ranch
Eastland Co, Texas
Kubota L5240 HSTC
So I popped this rock out of the ground on a hill and when I started to back down the hill my right front tire dropped into the hole left by the rock.
Was a little off camber and the weight of the tractor tilted to the right side and I now see grease has squirted out the tiny hole n the zerk.
Do zerks fail, did I kill it?
/ Blew my zerk? #2
Is the little check ball still there? If so push on it with the tip of a sharp object and see if it is still "springy". If so I would not worry about it. shoot some more grease in and go on.. But if you want to change it out change it out.:)
/ Blew my zerk? #3
When I got my tractor, new in 2009, there were two zeros that were plugged - too much orange paint, ha,ha. After removing them and fiddling with them for half an hour, I just replaced them. Subsequently, I unplugged them by soaking in lacquer thinner for a couple days.
/ Blew my zerk? #4
Zerks are cheap. Have a box with both metric, and SAE in the shop. Some times they plug up, some times you snag them off in the brush. I just grab a wrench and replace them.
/ Blew my zerk? #5
I got one so hot when I was burning up my tiller clutch on the PTO that the ball exploded out. I guess it got hot enough to boil the grease? It was red hot!
2014 Takeuchi TB260 Midi Excavator (A61572)
2014 Takeuchi...
Unverferth Seed Runner 3755 (A64119)
Unverferth Seed...
KUBOTA M108S TRACTOR (A64280)
KUBOTA M108S...
GAMOR MACHINE CO. 4R VEGATABLE SEED PLANTER, 3PT (A64280)
GAMOR MACHINE CO...
2022 EZ-GO ELITE...
2012 CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A65053)
2012 CATERPILLAR...
