Bleeding Brakes
/ Bleeding Brakes #1
70jd400
Fitzwilliam NH
JD 400 Industrial
Ok so I have replaced a steel hydraulic line and pulled of the left side axle housing to fix the diff lock and know i can not get the brakes bleed. I have made sure that the seals around the brake disk were not cut when i put that part back together (after i cut the first set putting it together). I had brakes before I started this project.:confused3: this is on a JD400 Industrial
/ Bleeding Brakes #2
Assume this is the JD 400? Suggest to attach this to the apparent thread where you are working on the 400 so readers can keep up. ;)
/ Bleeding Brakes #4
Did you have engine running while attempting to bleed the brakes? Is brake pedal height adjusted correctly? The check valves in utility tractor brake valve housing have a history of failing.
/ Bleeding Brakes
Yes tractor was running. I haven't changed or adjusted anything with the brakes because they were working before. I also changed hydraulic fluid and all filters. Trans filter hydraulic filter and the long round screen filter
Wolverine TL-12-72W 72" Skid Steer Tiller (A62679)
Wolverine...
New Holland 499 MoCo (A66408)
New Holland 499...
New/Unused Wolverine Quick Attach Auger (A65583)
New/Unused...
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 FREIGHTLINER...
(4) Ratchet Straps (A65583)
(4) Ratchet Straps...
2023 SANY SY225C EXCAVATOR (A63276)
2023 SANY SY225C...
