Bleeding Brakes
/ Bleeding Brakes #1
70jd400
Fitzwilliam NH
JD 400 Industrial
Ok so I have replaced a steel hydraulic line and pulled of the left side axle housing to fix the diff lock and know i can not get the brakes bleed. I have made sure that the seals around the brake disk were not cut when i put that part back together (after i cut the first set putting it together). I had brakes before I started this project.:confused3: this is on a JD400 Industrial
/ Bleeding Brakes #2
Assume this is the JD 400? Suggest to attach this to the apparent thread where you are working on the 400 so readers can keep up. ;)
/ Bleeding Brakes #4
Did you have engine running while attempting to bleed the brakes? Is brake pedal height adjusted correctly? The check valves in utility tractor brake valve housing have a history of failing.
/ Bleeding Brakes
Yes tractor was running. I haven't changed or adjusted anything with the brakes because they were working before. I also changed hydraulic fluid and all filters. Trans filter hydraulic filter and the long round screen filter
1979 Donahue Dump Trailer (A66285)
1979 Donahue Dump...
2007 TORO 3300-D CART (A66091)
2007 TORO 3300-D...
JCB 3TS-8T Compact Wheel Loader Skid Steer (A64553)
JCB 3TS-8T Compact...
HARDEE DITCH BANK MOWER (A64278)
HARDEE DITCH BANK...
155 (A64278)
155 (A64278)
2003 Ford E-450 Super Duty Passenger Bus (A61573)
2003 Ford E-450...
