Bleeding Brakes
/ Bleeding Brakes #1
70jd400
Member
Fitzwilliam NH
JD 400 Industrial
Ok so I have replaced a steel hydraulic line and pulled of the left side axle housing to fix the diff lock and know i can not get the brakes bleed. I have made sure that the seals around the brake disk were not cut when i put that part back together (after i cut the first set putting it together). I had brakes before I started this project.:confused3: this is on a JD400 Industrial
/ Bleeding Brakes #2
Assume this is the JD 400? Suggest to attach this to the apparent thread where you are working on the 400 so readers can keep up. ;)
/ Bleeding Brakes #4
Did you have engine running while attempting to bleed the brakes? Is brake pedal height adjusted correctly? The check valves in utility tractor brake valve housing have a history of failing.
/ Bleeding Brakes
Yes tractor was running. I haven't changed or adjusted anything with the brakes because they were working before. I also changed hydraulic fluid and all filters. Trans filter hydraulic filter and the long round screen filter
2022 EZ-GO ELITE...
John Deere 5000-Series Tractor Grill Guard (A65640)
John Deere...
2025 32in. Tilting Bucket Mini Excavator Attachment (A64553)
2025 32in. Tilting...
GOOSENECK SPOOL TRAILER (A65643)
GOOSENECK SPOOL...
2018 GEHL RS5-19 GEN3 TELESCOPIC FORKLIFT (A65053)
2018 GEHL RS5-19...
2018 Jeep Grand Cherokee Trackhawk 4x4 SUV (A64557)
2018 Jeep Grand...
