70jd400
Ok so I have replaced a steel hydraulic line and pulled of the left side axle housing to fix the diff lock and know i can not get the brakes bleed. I have made sure that the seals around the brake disk were not cut when i put that part back together (after i cut the first set putting it together). I had brakes before I started this project.:confused3: this is on a JD400 Industrial
