blades for lt 1046
/ blades for lt 1046 #1
kgkx125@hotmail.com
My mower is a cc lt 1046 (2005)- can anyone suggest a website for less expensive blades than oem
/ blades for lt 1046 #2
Man you must have razor wire tough grass! I'll be going on season 4 with the original blades on my 2544. I've never even had to sharpen them! The edges 'almost' look new yet. 'Course my Western New York 1.5acres is mostly closely cropped weeds with some 'grass' mixed in. It's all green and looks good to me!
Joel
Thanks for the reply. My turf consist of mostly san augustine with a lot of sand mixed in. I would guess the sand is the culprit. I probably go through 2 sets of blades a season at $68 a pop through my local cc independent retailer. My previous mower was a jd 178 in which the oem blades didn't wear nearly as fast. I guess I was assuming the metal in the cc oem blades were not as good.
/ blades for lt 1046 #4
I know exactly what you mean. I've got the same mower, and the blades seem to be really cheap. I'm mowing TIF bermuda, no sand no rocks, and still they look totally worn out.
I've searched all over and can't fine anything other than the the oem stuff.
Gator doesn't make a mulching blade yet either. :(
anthony
Found replacement blades for lt 1046 at mowerproducts.com for approx. $30. Blades were hard to look up on website. Called instead, salesperson was very informative and helpful. Hope this helps someone else outthere. Also called Gator Blades directly- no chance of them making blades for this mower within the next 2 years.
/ blades for lt 1046 #7
oops! went to mowerproducts.com and the site is gone!
Dang, you probably bought the last set:))
anthony
/ blades for lt 1046 #9
HI KG. welcome to TBN. If your cutting Sothern grass with sandy soil. My bet would be on a Low lift Blade, for longer life.
2002 Freightliner Allegro Bus Class A Motorhome (A61574)
2002 Freightliner...
Woodland Mills Sawmill (A65579)
Woodland Mills...
UNUSED SDLANCH SDLL60 STAND ON SKID STEER (A64280)
UNUSED SDLANCH...
2026 DEVELON DX27Z-7 EXCAVATOR (A65053)
2026 DEVELON...
2021 Unverferth 432 Rigid 4 Row 36-inch 3PT Ripper Bedder (A63688)
2021 Unverferth...
2015 Isuzu NPR HD Septic Pump Truck (A62613)
2015 Isuzu NPR HD...
