Blackberries, before and after
/ Blackberries, before and after #22
Just remember, don't eat the berries that grow below the waist... /forums/images/graemlins/grin.gif
/ Blackberries, before and after #23
</font><font color="blue" class="small">( re permanent blackbery eradication -
I was told by a Master Gardener that a flamethrower was more effective than Roundup because it kills the roots better.
Has anyone waited until the dead of winter then hit them with a flamethrower? Did did it accomplish anything?
)</font>
Yep, I've done it. Instead of coming back the next year, it wiped them out for about 3 years. But they came back.
With a vengence.
Steve
/ Blackberries, before and after #24
Sounds like its time to drag out the old flame thrower and get back to work. Maybe this time those nasty old black berries will learn their lesson. I would leave mine alone if they produced a good berry but the berries are tiny, deformed and just barely edible
Farwell
/ Blackberries, before and after #25
Roundup is almost useless to control blackberries in the NW. It will burn off the leaves but the root ball need to be killed to has success. You need to use Crossbow to kill them. Crossbow is 2-4-D which others have stated is a broadleaf killer only. To get complete kill the berries need to be sprayed now after the berries are gone and the plant is starting to go dormant. With the plant drawing everything into the rootball during its going dormant cycle the root ball with be killed and no more berries. But to totally eliminate berries here in the NW west you also need to elminate all the raccoons, bird and deer which are the greatest most efficient reseeders know to man.
Cheers
David
/ Blackberries, before and after #26
</font><font color="blue" class="small">( Roundup is almost useless to control blackberries in the NW. It will burn off the leaves but the root ball need to be killed to has success. You need to use Crossbow to kill them. Crossbow is 2-4-D which others have stated is a broadleaf killer only. To get complete kill the berries need to be sprayed now after the berries are gone and the plant is starting to go dormant. With the plant drawing everything into the rootball during its going dormant cycle the root ball with be killed and no more berries. But to totally eliminate berries here in the NW west you also need to elminate all the raccoons, bird and deer which are the greatest most efficient reseeders know to man.
)</font>
I'll second this. The 2-4-D stuff seems to work best on blackberries. I usually mix both 2-4-d and Round-up together and hit the blackberries with it at full strength.
Last year I tried to eradicate the blackberries from a little strip of hillside. I Round-uped everything(twice), then I tilled everything up and torched it with a propane torch (twice). the blackberries came back as if nothing had been done to them.
I seeded the hillside with wild flowers so that wasn't dense enough to keep out the seeds and stuff. Next year I'm tilling it all up and planting grass. I'm going to control the blackberries with 2-4-D as needed.
/ Blackberries, before and after #27
If you mow close and often, no chemicals are needed. I have no problem whatsoever with blackberries.
/ Blackberries, before and after #28
</font><font color="blue" class="small">( Sounds like its time to drag out the old flame thrower and get back to work. Maybe this time those nasty old black berries will learn their lesson. I would leave mine alone if they produced a good berry but the berries are tiny, deformed and just barely edible
Farwell )</font>
Replace the wild berries with thornless plants from Stark Brothers or other berry plant growers. Berries as big as your thumb, and they'll out compete the wild ones.
Berries like cool roots and warm tops, so full sun is best with mulch 4-8 inches thick on the roots. Berries like at least one annual cultivation effort, but are otherwise low maintenance.
I'd never use chemical control agents where you might plant a food crop in the future. Chemicals are for drainage ditches and so forth.
Pat
/ Blackberries, before and after #29
Pat,
Thanks for the link, I added it to my favorites. In the next couple of years I plan on planting about 1/2 acre into fruit bearing plants and am in the process of educating myself as to the best methods to get healthy great tasting fruit.
The berries that I now have are wild and pretty much garbage plants mixed in with poison ivy and bramble bushes. They are also growing in an area that at some point in the future will be a pond so they will have to go. The area where they are growing is pretty much unaccessible to my tractor due to the grade and wet ground. I have already sprayed them with Round-up and it does not seem to have touched them other than turning the leaves brown. Another poster mentioned Crossbow and I am going to try that next. If I was going to plant in the berry area I would not use the chemicals.
Thanks.
Farwell
/ Blackberries, before and after #30
Yes, brambles are among the hardest plants to eliminate because they can root propagate. The root blade mentioned is a useful tool, but it you can't get a tractor or other machine in to dig, they really are the devil to remove.
I wouldn't say impossible, but close to it. A weed burner, also mentioned, is a good idea but becareful with it, you can start a mean brush fire with one.
/ Blackberries, before and after #31
I am missing the blackberry pies since I bought my tractor. /forums/images/graemlins/smile.gif Trouble with the NW weather is that everything grows too well. Alder and Blackberries....
/ Blackberries, before and after #32
24 inch taproot. (Car keys for size comparison.)
/ Blackberries, before and after #33
That is some serious tap root. If you have many like that a dozer or an excavator may be in your future.
Farwell
/ Blackberries, before and after #34
</font><font color="blue" class="small">( If you have many like that a dozer or an excavator may be in your future.)</font>
I wish!
Actually these berries are in the steep banks between terraces, in an old apple orchard. See the fifth picture in my More Blackberries thread.
More Blackberries
I can't cut into the soil there without starting erosion that would wash out the terraces. That's why I'm over here in Highbeam's thread, I'm hoping to learn more about eradication.
/ Blackberries, before and after #35
They do not have thorns but I have pulled out a couple hundred Shumac plants over the past couple of years. They do not have a tap-root but they do have roots that spread over a wide area and if I don't get it all, a bunch of new plants show their heads. I use a 5/8 inch poly rope with a small hook on the end to wrap the plant base and pull it out with my tractor. I have thought about getting a grapple hook and trying to hook them and pull them out that way. May work on Black berry bushes as well.
Farwell
/ Blackberries, before and after #36
</font><font color="blue" class="small">( I do the schmearing and cutting in 1 pass. I drop my FEL in the "float" position, curled slightly above level. - have_blue)</font>
You must have tougher ears than I do to drive in with the bucket low! /forums/images/graemlins/grin.gif
2022 Sany SY215C Hydraulic Hammer (A62679)
2022 Sany SY215C...
John Deere 5420 Tractor with Quicke Loader (A64047)
John Deere 5420...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A65643)
2020 TROXELL...
2004 Chevy 2500 Pickup Truck (A66408)
2004 Chevy 2500...
New/Unused Outdoor Propane Patio Heater (A65583)
New/Unused Outdoor...
Pickup Truck Ladder Rack (A62613)
Pickup Truck...
