Black Smoke
/ Black Smoke #1
darius
Kansas City
Deere 318
I am looking at a Ford 1210 with 950 hours. It gives off a little bit of black smoke when running (I am looking at it sat., current owner mentioned the smoke). He says it sits most of the time and hasn't been used very much. It hasn't been run enough to warm up much.
So my questionis this something to be concerned with? What might it be an indication of? Also, what else should I be looking out for on this tractor?
It's an 83 Ford 1210, 4x4, HST with 950 hours.
Thanks.
/ Black Smoke #2
I have a Ford 1210 of the same vintage. It smoked since the day I got it (bought used, forgot how many hours). It smoked more at higher RPM's. I posted a message "Tractor Quit Smoking" somewhere on the board. After sitting for the best part of a year, it smoked a lot. I added some diesel fuel treatment, and that greatly reduced the smoke (back to the normal amount, not very bad). I blamed it on old fuel....................chim
/ Black Smoke #4
Rdbrum is correct, check the air filter, black smoke is from the warm cylinders not completly burning all the fuel in the cylinder, possible if lack of air flow.
White smoke is cold cylinders, or basically it is unburned fuel and mostly is a fact of cold-weather diesel operation.
Grey smoke is worn rings/burning oil (i think)
Also could be a timing issue with the injectors if they slipped.
(highly doubt it)
John
New/Unused Wolverine 78in Quick Attach Land Leveler (A65583)
New/Unused...
2016 CATERPILLAR D6K2 LGP CRAWLER DOZER (A65053)
2016 CATERPILLAR...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
2018 TAKEUCHI TL8 SKID STEER (A59914)
2018 TAKEUCHI TL8...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
New/Unused ATS 40 Gallon 2 Stage Air Compressor (A65583)
New/Unused ATS 40...
