Black Smoke at start up and under load
   / Black Smoke at start up and under load #11
From everything I've been able to find out - with decent maintenance a typical Yanmar should only being feeling it's oats at 2000 hours.
Back when I bought mine there was a 4500 in the shop - split and torn down for a drivetrain rebuild. Seems like the owner started having trouble getting it out of 4wd and ended up leaving it in all the time - with considerable hard pavement travel. Something eventually gave out in the driveline but the engine was still solid and strong. It was obvious this 4500 had not been babied - and it had 5500 hours on the clock.
The bigger question may be what had been done for/to your particular 4100 before you got it, but if it's been maintained reasonably to the schedule - and you continue the same care - you'll likely be good for a very long time.
   / Black Smoke at start up and under load #12
I have a 2 cyl diesel in my JD 650 4wd. When it starts to get under a load it will start to puff a little gray smoke. Does this mean there is a problem. It does not lack for power or seem to miss a beat. Just curious. I just give it a little more fuel and she clears right up. Only has 531hrs.
2023 Kubota Z252KH-54 Zero Turn Mower (A56436)
2023 Kubota...
Unused Kivel 48" Pallet Fork Attachment (A55272)
Unused Kivel 48"...
2025 Forklift Safety Basket (A56857)
2025 Forklift...
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
14ft x 20ft Single Garage All Metal Building (New/Unused) (A59225)
14ft x 20ft Single...
(3) ALUMINUM STEP LADDERS (A58374)
(3) ALUMINUM STEP...
