Black Smoke at start up and under load
   / Black Smoke at start up and under load #11
From everything I've been able to find out - with decent maintenance a typical Yanmar should only being feeling it's oats at 2000 hours.
Back when I bought mine there was a 4500 in the shop - split and torn down for a drivetrain rebuild. Seems like the owner started having trouble getting it out of 4wd and ended up leaving it in all the time - with considerable hard pavement travel. Something eventually gave out in the driveline but the engine was still solid and strong. It was obvious this 4500 had not been babied - and it had 5500 hours on the clock.
The bigger question may be what had been done for/to your particular 4100 before you got it, but if it's been maintained reasonably to the schedule - and you continue the same care - you'll likely be good for a very long time.
   / Black Smoke at start up and under load #12
I have a 2 cyl diesel in my JD 650 4wd. When it starts to get under a load it will start to puff a little gray smoke. Does this mean there is a problem. It does not lack for power or seem to miss a beat. Just curious. I just give it a little more fuel and she clears right up. Only has 531hrs.
2007 FORD F-550 XL SUPER DUTY CHASSIS TRUCK (A58375)
2007 FORD F-550 XL...
PALLET OF MISC PARTS (A58374)
PALLET OF MISC...
2008 JLG  800S MANLIFT (A58216)
2008 JLG 800S...
207280 (A52708)
207280 (A52708)
TANK MANIFOLD (A58216)
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
