Black Smoke at start up and under load
   / Black Smoke at start up and under load #11
From everything I've been able to find out - with decent maintenance a typical Yanmar should only being feeling it's oats at 2000 hours.
Back when I bought mine there was a 4500 in the shop - split and torn down for a drivetrain rebuild. Seems like the owner started having trouble getting it out of 4wd and ended up leaving it in all the time - with considerable hard pavement travel. Something eventually gave out in the driveline but the engine was still solid and strong. It was obvious this 4500 had not been babied - and it had 5500 hours on the clock.
The bigger question may be what had been done for/to your particular 4100 before you got it, but if it's been maintained reasonably to the schedule - and you continue the same care - you'll likely be good for a very long time.
   / Black Smoke at start up and under load #12
I have a 2 cyl diesel in my JD 650 4wd. When it starts to get under a load it will start to puff a little gray smoke. Does this mean there is a problem. It does not lack for power or seem to miss a beat. Just curious. I just give it a little more fuel and she clears right up. Only has 531hrs.
SKID STEER ATTACHMENT HAMMER (A58216)
SKID STEER...
1992 Trail-Et (A57148)
40ft High Cube Shipping Container (A57453)
40ft High Cube...
2023 WRANGLER 5500T ARTICULATED WHEEL LOADER (A58216)
2023 WRANGLER...
LOT: Clevis Hook, Snatch Block (A59076)
LOT: Clevis Hook...
Mini-Skid Steer Vibratory Roller (New/Unused) (A59225)
Mini-Skid Steer...
