Bizarre log splitter idea
   / Bizarre log splitter idea
Great info everyone.
Im less concerned about speed cuz i would use this for bigger rounds only. The usual rounds ill split by hand. Looking at a 3x8 cylinder plus hoses probably total 200$. I dont think id get a 3 point so id be looking at 1000 for the huskee or yard machine. Im on tsc mailing list but have never seen a coupon
   / Bizarre log splitter idea #12
Just my opinion only,
But I think you are going to be utterly dissapointed with a 3"x8" cylinder.
Not enough tonnage or stroke length. I think it is going to be a wasted $200
<But I think you are going to be utterly dissapointed with a 3"x8" cylinder.>
I have the feeling you're right.
Maybe i'll "upgrade" the idea.
If I spend the same money on a 3x18 cylinder, use some other steel I have for a beam, and run it off the curl control the same way......
I can always improve it later when I have money.
   / Bizarre log splitter idea #14
A 3 in cyl with 1.5 shaft, at 2500 psi will only produce about 17,671 lbs or about 8.8 tons of force.
Gee Wiz, that's all, 8.8 tons? How do any of the 3 pth splitters like the Powerhorse work?
so a 4x18 cylinder will give me more useful force, but be slow. At 8.3 gpm how slow?
   / Bizarre log splitter idea #18
A 4" cylinder would give you about 16 tons:thumbsup:
And the speed wouldnt be too bad. You have to keep in mind that a store-bought unit would have a 2-stage pump. Usually something like 16GPM @ 650PSI and 4 GPM @ max PSI. And they rate the cycle times NO load, or on the 16GPM stage.
As soon as the wedge meets a little resistance, it drops down to the 4GMP, which is really slow.
Whereas you will maintain a faster speed while splitting.
So look at it this way, while the wedge is in the wood, you will be about twice as fast as a commercial splitter. But while NOT in the wood, you will only be half the speed.
A 4x18 cylinder (assuming a 1-1/2" rod) your speeds would be 7.2sec extend and 6 sec retract. That is a 13.2 second cycle time. Store units are about 15-16 seconds, but using a longer 24" cylinder also.
Here is a good website for the calculators if you want to play around
Baum Hydraulics Corp :: Spec Calculator
Cool thats not bad at all! Looks like all i need is:
4x18 cylinder
3'x1/4 hose
5xx1/4 hose
2 male quick fittings
Something to use for a wedge
I guess i should go with longer hoses so i can tow or put on the 3 pth
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
1997 EZ S/A Spool Trailer (A49461)
1997 EZ S/A Spool...
2015 Ford F-150 Ext. Cab Pickup Truck (A50323)
2015 Ford F-150...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
2017 Ford F-650 Mason Dump Truck (A50323)
2017 Ford F-650...
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A51039)
2019 New Holland...
