Bizarre log splitter idea
   / Bizarre log splitter idea
Great info everyone.
Im less concerned about speed cuz i would use this for bigger rounds only. The usual rounds ill split by hand. Looking at a 3x8 cylinder plus hoses probably total 200$. I dont think id get a 3 point so id be looking at 1000 for the huskee or yard machine. Im on tsc mailing list but have never seen a coupon
   / Bizarre log splitter idea #12
Just my opinion only,
But I think you are going to be utterly dissapointed with a 3"x8" cylinder.
Not enough tonnage or stroke length. I think it is going to be a wasted $200
<But I think you are going to be utterly dissapointed with a 3"x8" cylinder.>
I have the feeling you're right.
Maybe i'll "upgrade" the idea.
If I spend the same money on a 3x18 cylinder, use some other steel I have for a beam, and run it off the curl control the same way......
I can always improve it later when I have money.
   / Bizarre log splitter idea #14
A 3 in cyl with 1.5 shaft, at 2500 psi will only produce about 17,671 lbs or about 8.8 tons of force.
Gee Wiz, that's all, 8.8 tons? How do any of the 3 pth splitters like the Powerhorse work?
so a 4x18 cylinder will give me more useful force, but be slow. At 8.3 gpm how slow?
   / Bizarre log splitter idea #18
A 4" cylinder would give you about 16 tons:thumbsup:
And the speed wouldnt be too bad. You have to keep in mind that a store-bought unit would have a 2-stage pump. Usually something like 16GPM @ 650PSI and 4 GPM @ max PSI. And they rate the cycle times NO load, or on the 16GPM stage.
As soon as the wedge meets a little resistance, it drops down to the 4GMP, which is really slow.
Whereas you will maintain a faster speed while splitting.
So look at it this way, while the wedge is in the wood, you will be about twice as fast as a commercial splitter. But while NOT in the wood, you will only be half the speed.
A 4x18 cylinder (assuming a 1-1/2" rod) your speeds would be 7.2sec extend and 6 sec retract. That is a 13.2 second cycle time. Store units are about 15-16 seconds, but using a longer 24" cylinder also.
Here is a good website for the calculators if you want to play around
Baum Hydraulics Corp :: Spec Calculator
Cool thats not bad at all! Looks like all i need is:
4x18 cylinder
3'x1/4 hose
5xx1/4 hose
2 male quick fittings
Something to use for a wedge
I guess i should go with longer hoses so i can tow or put on the 3 pth
2018 JOHN DEERE 204L WHEEL LOADER (A51242)
2018 JOHN DEERE...
2013 AMSIG S/A Solar Towable Message Board (A50322)
2013 AMSIG S/A...
Morooka MST 660VD Tracked Dump Truck (A51039)
Morooka MST 660VD...
2019 BOBCAT T770 SKID STEER (A51242)
2019 BOBCAT T770...
MAXUM 1000 TRIPLEX PUMP POWERED BY 3412 CATERPILLAR ENGINE (A50854)
MAXUM 1000 TRIPLEX...
2011 FREIGHTLINER M2 26FT BOX TRUCK (A50505)
2011 FREIGHTLINER...
