Birdshot into a makeshift slug by cutting the hull? Video
   / Birdshot into a makeshift slug by cutting the hull? Video #21
.and you gotta pay attention to the details.
Foggy...that is so true in this case especially but also in all parts of our lives...the Devil hides there...Right ?
How true this is, and there-in lies more danger-definitely .
   / Birdshot into a makeshift slug by cutting the hull? Video #22
Having done this in the past.. (having scored the shell around the wad and firing it through a straight tube barrel) I can say it's not harmful in my experience. That's not to say the next one wouldn't have blown the barrel off the shotgun, but it didn't do any harm that we could see, other than a hel* of an ugly hole in whatever we shot at.
I wouldn't recommend it for hunting anything, but it makes a nice "demolition round".
The straight tube barrel was a Winchester 37 single shot sawed off to 24 inches. Makes a deadly bird/rabbit gun. I still have it.
Sean
Back when I was in my 30s some hunting friends would use this technique to get geese to rise off a lake. Drop a few of the cut ends into the water and away they fly. You would be surprised how far a cut end will fly. We used the shot shells that had the clear case and you could see the insides and knew where to cut.
   / Birdshot into a makeshift slug by cutting the hull? Video #23
Most turkey Shoots I been to in the last 10 years havd always required the participants to use the same shells, theirs.
+1 Same here, but unless closely watched - some folks took just a moment to "fix" their shell, change a choke tube, etc., etc.
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/nerve-alive-supplement-reviews-inspired-by-nervecalm-for-natural-nerv-1044754
https://www.accessn...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A48081)
2015 Ford F-550...
2020 Freightliner Cascadia 126 T/A Sleeper Cab Truck Tractor (A49461)
2020 Freightliner...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
Tubing A500 Grade C 6in. SQ X 1/4in. X 28ft. (A50860)
Tubing A500 Grade...
7 ft. Rotary Cutter & Log Splitter (A50860)
7 ft. Rotary...
