Biggest disc a MX5100 can handle
/ Biggest disc a MX5100 can handle #1
LD1
Epic Contributor
Central Ohio
Kubota MX5100
What is the biggest you guys have ran?
I am in need of a disc. Dad always had a disc, and we always used it quite a bit. He actually just had a couple, and always see these little 6-8' discs pretty cheap. So he fixed his up and sold it and planned to buy an other in need. But the craigslist well seems to have dried up.
I dont use a disc for farming or anything. Sometimes we plow the garden and then just once over it with the disc before tilling just so its not so rough to drive over with the tiller. But I use a disc more for construction type work. Leveling/smooting uneven areas, dressing up around trenches dug with the backhoe, breaking up the hardpack to sow some grass seed, etc.
Got a potential job for a neighbor....if it pans out....to put a few thousand feet of sodway back in her field. Discing would be great before running the broadcast seeder, then cultipacker.
Long story short.....local farmer I have know all my life has a transport disc for sale. Just think it may be too big. I am sure he would let me try it first, but wonder what the TBN collective's thoughts were.
Its a JD210.....I think its considered a 12'. Not sure how much it weighs, or pan diameters/spacing. All I know is its a JD210, needs some work (bearings), and he doesnt use it anymore as he has upgraded to larger stuff to match his ~140hp 7230 deere premium tractors. The tractor that he always pulled this disc with was a 2355 4wd. 6600# tractor with much larger tires and 15HP more. But he said it hardly worked that tractor.
I know the 7.5' 3PH disc w/16" pans and the 6.5' 3PH disc w/18" pans were nothing at all behind by L3400. Both were angle frame discs. Thats the extent of my discing experience. We used to have an old rusty tow behind disc....maybe 10', and not very heavy. Pulled that with an 8n. But this 210 disc looks HEAVY.
/ Biggest disc a MX5100 can handle #2
A wheeled Disc Harrow has hydraulic power to raise the pans, relative to the frame, so you can adjust the tilling depth, therefore draft force, much more than with a non-wheel Disc Harrow. Do you have rear hydraulic ports on your MX5100?
I do not believe I have personally seen a wheeled Disc Harrow with pans less than 22" in diameter, which is when Disc Harrows can reasonably used for some primary tillage, as opposed to secondary tillage.
Twelve foot width seems like it might be cumbersome for your tasks ~~ ??
Taking apart old Disc Harrows can be tough. Agri Supply has more Disc Harrow pans and bearings in stock than any other vender.
~~ I will hold your beer.......
Yes I have remotes. You must have missed that thread;)
I couldnt find any specs online for the disc regarding weight, pan diameter, or spacing. I'll have to stop and look at it sometime.
Aint gonna do anything at least til crops are harvested. That way I can hitch to it and test it out in the field before deciding. But even if I dont like, I still may buy if price is right.....fix and paint....then resell.
/ Biggest disc a MX5100 can handle #4
Just from memory right now, but think the manual for my 4800 says 84" disc max. I will check later to confirm.
I ignore the manual. Too conservative. But yes, it lists a max 880# 84" disc. Something my L3400 would pull with ease.
Manual also says 1000# 84" bushhog is max. So my 96" 1620# cutter is too big.
IT says 72" max rear blade also. I have an 84" and currently looking at a 96"
I didnt buy a 51HP 4wd tractor to be limited to implements an 8n ford can run.
/ Biggest disc a MX5100 can handle #6
That's a lot of disc. If you're pulling it with an agressive set up in a deep plowed field you will know it's behind you but if you're using it like you mentioned for smoothing out or roughing up a pasture it should pull great.
For what you'd be using it for this is not the best smoother JD built. I use an 8' Blanton 3ph for smoothing and a cheap ugh... light weight Howse for cutting. The Blanton is a heavy disc and it and the JD 210 is built with a simular design only mine is 3ph. It's not the best smoother Blanton made either but it works better now that I played with it and moved stuff around.
I've got the back 2 sections turned backwards I guess you'd say. Instead of the cutting into the ground with the concave facing forward they are facing backward. I know the disc aren't designed for this but hey you don't know till you try. Anyway it smoothes better but you wouldn't want to drag it across the pasture that way but it's fine on loose dirt.
The ideal situation would be to have the disc sections where you could easily turn them around.
At first glance it looks like a normal disc but look closely how the back sections are mounted. I have the front sections set up about 1/2 aggressive and the back only slight aggressive.
/ Biggest disc a MX5100 can handle #7
I've got the same tractor minus a few horsepower. There's no data on the drawbar HP for these machines, but based on the data from the IH hydro tractors of days give past, drawbar HP seems to be around 3/4 of PTO HP, maybe a little less. So I think you're looking at a drawbar HP rating around 30-35 for your MX. With 4wd and loaded rears, I don't think you'll run out of traction, especially with some weights or the loader up front, but you may not have the power to pull the disc at the correct speed to do the job correctly in some cases. As Jeff mentioned, you can reduce the depth to adjust the power needed to pull, though. Personally, I'd give it a shot. You can always make it smaller if need be.
Out of curiosity, though, why not just use a rototiller?
/ Biggest disc a MX5100 can handle #9
There are so many variables, that without actually seeing the areas to be disked, all anyone is doing is guessing. Type of terrain, type of disk, size of pans, overall weight. 3pt, wheel, old pull type, desired angle, desired depth.
I have a 75hp, 12,000lb tractor that I use to disk with as well as a small dozer and an old Cat D6. We have 6', 8' & 12' Kielfer offset pull disks. With my conditions, the 8' disk with new 22" pans weighs in around 3000lbs. On the 2nd disking (9" deep) there are areas where it is all the tractor can handle. Your tractor would not budge it. I can pull the 12' disk on flat ground only and only a single pass, won't do it at all on a second pass.
So for those people that are always saying that there tractor can pull such and such and it seems big, need to get ALL the details. Here's a picture of a smaller 13' disk that requires something like 400hp to pull around. :rolleyes: Oh, each of those pans puts over 900lbs of pressure to the ground.
I remember some guy that use to be on here quite often that was going on about his 60hp 6000lb tractor pulling a 14'-16' disk.(I don't remember now) Really? I asked for pictures several times, never got any. Seems like that would be a hard pull even with small pans, but I don't really know, all I've ever pulled are 22" pans.
Again, lots of variables that should be considered.
Good luck with your decision. ;)
/ Biggest disc a MX5100 can handle #10
We've got a 13' Athens 131 flex disc harrow. I think the thing weighs in excess of 3K. Talk about a bugger to pull. It would bring our AC 180 to it's knees. We've also got a 12' Taylor Way that is much easier to pull. We had a smaller 8' offset that we sold but pulled it with D17's. Did well with loaded tires.
I have used the tiller many times. (even put gauge wheels on it). And it does a real nice job fixing areas of the yard.
But not really needed to do that find of a finish in the field. And its small....54", and real slow going. I'd be all day prepping a ~2500' waterway for seed with a 54" tiller. Where the disc would do it in a few passes down and back, and at something more than 1 mph.
I also like using a disc and pulling over top of a windrow of dirt that gets shoved back in a trench dug by the backhoe. Backfilling with a loader.....leaves an uneven trench fill that settles uneven and equally rough once it is finally settled. The disc evens things out nicely.....the another pass down each side with the rear blade to windrow back overtop of the trench.....excellent results. Not something I could do with the tiller.
I have no experience with that disc harrow...
According to this thread is a double offset that may have issues penetrating hard pan...
JD210 12 Ft. disc - Yesterday's Tractors
Not looking for a primary tillage tool. And I am sure it will penetrate better than the 6-8' angle iron frame 3PH disc's I am used to.
Here is a picture so people get an idea what I am looking at. (This isnt the actual disc, rather one just like it I found online.)
/ Biggest disc a MX5100 can handle #13
Since its not 3pt, I don't think youll have the weight to pull that size of disc. Discs require lots of horsepower and lots of weight. If it does pull it, I don't think its going to like it very much. On 2nd pass my old school 6' discs will cause me to loose traction now and again, but HP isn't an issue...
/ Biggest disc a MX5100 can handle #14
The wheels bear whatever load the operator desires, so draft force may or may not not be a limiting factor.
However, this non-Three Point Hitch towed Disc will require a lot of room to turn and OP wants to use it in space limited conditions. I do not see how you could move this long-tongue Disc in reverse more than a few feet.
"I use a disc more for construction type work. Leveling/smooting uneven areas, dressing up around trenches dug with the backhoe, breaking up the hardpack to sow some grass seed, etc."
/ Biggest disc a MX5100 can handle #15
He might be able to pull it with about 3-4 inches in depth. But at reduced speed, may not get good results. I know pulling my Amco 9 foot offset, it needs speed to turn the sod over correctly. Too slow and the sod just plops back were it was. He might also think about a drag harrow for seeding. I love my 10 footer and pull it with the loader bucket around the pond. 11-9-13 Drag Harrowing Dam.jpg11-9-13 Dam Baby Smooth.jpg
Buy it and try it...............then resale it. That is what I thought before buying my 9 foot offset.............then fell in love with it.4-2-13 RED Disc Sees Daylight.jpg4-6-13 Luke and Disc in Dirt.jpg
hugs, Brandi
I wouldnt really say I will be using in space limited conditions. The field tile and trenching done is usually in the middle of big fields.
And even around my house and pond....nothing is real tight. 1 acre pond, on 8-1/2 acres total.
