Bigger tractor with cab??
/ Bigger tractor with cab?? #41
Ken,
I was going to suggest the DK65C, but Rowski wants hydro.
The DK65C would be to much power,, /forums/images/graemlins/wink.gif
RedDog
/ Bigger tractor with cab?? #42
The L5030 will be all the power needed for his snow blower and the HST will be about the smoothest he can get. I really liked my L48 power which shares the same engine. For versatility, he will be all set.
/ Bigger tractor with cab?? #43
Thanks RaT.
I think the hydro on the 5030 is actually better, modulation wise than my 3710 was. The cruise lever is a big improvement. I use the cruise lever to "drive" the tractor about 90 % of the time.
Daryl
Funny you mention about driving the tractor with the cruise level. I do the same (with the L4330hst) when on the road. We have lots of rises and dips in the roads. I use the cruise to maintain my rpm as I'm driving along the road. To bad they did have cruise for reverse.
/ Bigger tractor with cab?? #45
Derek:
I think that would be a big liability problem. Imagine the cruise in reverse and when you get right on top of an object, say your car and you forget the cruise is actuated (remember, you are looking backward, not at the dash light) and you run into your car), wow.
That is my favorite feature as far as controls go. Second is the loader joystick.
My suggestion for Kubota is to place a 4WD indicator light in the dash. It's really hard to determine whether you are in or out of 4WD as the actuator lever is on the left side down by the floor. You have to lean over and actually look at the position of the lever to tell. Not that I use 4WD very much.
/ Bigger tractor with cab?? #46
Derek, I rarely use the cruise control, but it is about the easiest one to use made. It could actually be a hand control for HST for someone who cannot use their feet. The reverse ability is out and as Daryl mentions for pretty obvious reasons. You will find if you should get a Kubota HST that those bumps and things become something that your foot will actually sense out as you go. That is to say, while going forward (or reverse) you sense the bump and your foot will instantly react slowing the tractor down to smooth it out. It will be second nature. To draw an analogy, it's much like the learned response you develop while driving a Bobcat skid steer. If you have never driven one, your first 5 minutes on one is a memorable experience. Hope you get it all straightened out. I would think that that T-8 powered landscape rake with a HST would be a combination you will not be able to match with any other design. It works superb with my Pro 8 from Harley. Rat...
/ Bigger tractor with cab?? #47
Ledebuhr1:
Got my camera back. Here is a picture of the joystick in relation to the seat.
/ Bigger tractor with cab?? #48
Here is another picture, this time from inside the cab. That's my knee in the picture. The joystick is right at arms length with your arm comfortably bent.
/ Bigger tractor with cab?? #49
Rowski:
I finally extracated my camera from the in-laws.
Here is a picture with my new Lucknow 78" on the back of the 5030. It's starting to snow here. Maybe I will get to use it.
/ Bigger tractor with cab?? #50
I've seen them mount that joystick on non cab models as well. It is very smooth from my fooling with it without the engine running. At the time I thought it was added for a person that may have needed assitance. I soon realized it was designed for the cab model yet there is no reason a person who does not have a cab could not use it if they liked it.
/ Bigger tractor with cab?? #51
RaT:
Check out my new blower. Looks "industrial" doesn't it??
I'll start a thread under "implements" with all the photo's.
/ Bigger tractor with cab?? #52
5030,
Thanks for the pics, how much extra was that joystick??
Do you know if Kubota makes a rearview mirror so that you can see the rear impliment without turning around?? I thought it would be handy for you when using the blower.
now if the snow that the weathermen predicted would just come.
/ Bigger tractor with cab?? #53
Guys,
I am late to this discussion but I will just add that the TNs are great tractors.
The D or S models have cabs that are very comfortable.
Fogging of the windows is not a problem because you can turn the front AC/heat vents in different directions.
One can blow on the front glass, one on each side window, etc...
You have a built in sun screen that pulls down in front of you for early evening work.
I also agree with the power and traction statements.
I have not got mine stuck yet, and I have managed to get everything else I own stuck several times.
I started using it to haul a dump trailer full of concrete and rocks. No problem even in soft mud and on steep hills.
This task was too much for a 4x4 F250 and I grew tired of having to save the truck with the TN.
Fred
2015 John Deere 310SL 4x4 Extendahoe Loader Backhoe (A61572)
2015 John Deere...
Case IH Onland 3pt 6 Bottom Flip Plow (A64119)
Case IH Onland 3pt...
2014 Lincoln MKS Sedan (A61574)
2014 Lincoln MKS...
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
karcher pressure washer (A61567)
karcher pressure...
1987 International 1954 Elliott ECE 3-65H Telescopic Boom Lift Truck (A61573)
1987 International...
