Bigger HST machines.
   / Bigger HST machines. #81
The fact is that gear tractors are going away. Maybe not soon but they are going to fade away just like manual transmissions in vehicles. first it was cars and pickups. Now getting a stick in a semi is getting harder. The old farmers are dying off and the younger ones taking over are more open to not dealing with shifting or clutches. Even power reversers are going to be mated to some sort of stickless transmission.
Let's face it. Gear was king because they were cheap and mostly bullet proof. Nobody put a computer into a tractor. Operators just expected to spend the day pushing in a clutch and shifting gears. Lots of things have gone by the wayside. Manual windows in cars and AC being optional. We as consumers have grown accustom to spending more money. I expect in 10 years we'll see a form of hydraulically controlled automatic shifting transmission that will operate just like HST in the 50hp to 100hp tractor range. You'll just control the speed with a pedal, like HST, or a lever. It'll be independent of engine speed so the PTO can be ran at speed without impacting tractor speed.
It just makes sense since driverless vehicles are slowly becoming a thing. That also is going to doom manually shifting gears.
My family members operate farms and HST tractor's there are rare and they have many, many tractor. All larger and with more HP than the ones you speak of.
To summarize: you want a M7060 in HST that is the same weight as your MX so you can mow 5 acre lots and not be bounced around. All you really want is a smoother ride. It has nothing to do with a larger tractor.
Wonder if you can get some air ride shocks for the MX? Maybe some welding skills and this kit! Amazon.com: Front Axle Air Ride Kit for Freightliner And Kenworth: Home Improvement
Fendt is out the 207 weights 8200#.
Where did I say I wanted a 7060 that weighs the same as a MX? Putting words in my mouth makes you look foolish. As does the notion of modifying a semi air-ride system to put on a tractor that has ZERO suspension movement
I absolutely love the Kubota MX series with the HSt transmission, but I could see the need for some 65 to 85 horsepower tractors with an HSt for loader work. I'm thinking hay tractor, grapple tractor.
My mx5200 hst is the tractor of choice for numerous tasks around the farm, but it's too small to be the feed tractor. You need a lot more machine to slog around muddy fields carrying hay bales (round) to the cows.
If I'm still at my in-laws farm when an 80-90 hp hst is available that will be my next tractor-maybe. I still need a tiny hst for yard work. I might get a 25hp hst first. But my fil already has all the geared tractors I'll ever need. Not going to be getting any more of those regardless of how efficient people say they are.
You seem to get exactly what/why I want what I want👍
   / Bigger HST machines. #84
You're carping about an 8000 lb Fendt being too heavy, it's well documented you seek 70+- HP in the MX weight class.
Yeah, the air shock thing is pretty foolish.
Well documented?
I said I don't want a 8000 pound 60-70hp machine.
In what way does that mean I want a 3800 pounder like the MX?
Infact BOTH tractors I keep mentioning....the m7060 Kubota and Deere 5075 are BOTH right around 5000# machines.
Why are you trying to create an argument where there is none?
   / Bigger HST machines. #86
WTC, the guy asked a simple question and is taking antagonizing baiting from ppl needing to thrust their chests out and begin blaming him for things he's stated.
LD knows what he wants for his specific needs and is being flogged from certain folks for not wanting or saying the right thing in their eyes?
The rest of this country is going bat-***** crazy and that doesn't mean this place should.
LD knows what he wants for his specific needs. End of story.
I wonder LD if a radial tire would acquire what you seek?
I know they give a smoother ride on even terrain and used a lot in Europe where they do a lot of street traveling w their tractors. I don't know enough to say how they are in the rough.
Perhaps someone with specific experience in this regard could chime in.
I wonder if it has been too much covid isolation? This forum used to be a helpful and peaceful place to hang out? Is this the start of a downturn?
Seriously....if I wanted to deal with the drama seekers I'd ditch this forum for Facebook. I though we were better than that here?
Not sure about radials? I have thought about going to R4 fronts many many times. The problem is finding a 6-lug 16.5 rim. I think it must be Kubota only thing cause skid loaders are 8. But my thinking is the wider flatter tire as opposed to skinny and more rounded is not gonna feel near as many good prints in many of the horse/cow pastures I mow.
   / Bigger HST machines. #88
It doesn't sound like you need more horse power and it doesn't sound like you need more weight. Just bigger tires for a smoother ride. So install larger tires on your present tractor. You can go wider or taller or both if you want. As long as you maintain the front to rear ratio with the four wheel drive it shouldn't be a problem.
Edited to add that yes radial tires would defiantly improve the ride. As for a specific rim have one made. There are company's that do that or a competant machine shop can make a center for an existing rim. I would not install r-4's though. They are about the roughest riding tire available at this point.
   / Bigger HST machines. #89
I erased the last part because it didn't answer to your hst desires.
You wanted smooth plus hst.
The question is still out to my Mahindra connection about the larger tires on the 2660 pst and not the hst and if they are considering the 2670 for future hst and if they could do a tire swap from the pst to hst.
Might find out tomorrow.
   / Bigger HST machines. #90
and the hst part? (I forgot about that as well)
Toro hr:2213.5 (A56859)
Toro hr:2213.5...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
JOHN DEERE 630 DISC HARROW (A52708)
JOHN DEERE 630...
2017 GMC SIERRA 1500 (A58214)
2017 GMC SIERRA...
Central Machinery Horizontal/Vertical Bandsaw, S/N 366852447, 120 Volt (A59076)
Central Machinery...
(2) METAL & WOOD STORAGE RACKS (A52708)
(2) METAL & WOOD...
