Bigger HST machines.
   / Bigger HST machines. #71
Wow....I was extremely hopeful for a moment.....
Then I read the brochure.
The 2670 is ONLY offered in PST....no hst.
The 2660 is offered in in BOTH pst and HST.....BUT.....look at the ag tire sizes....
THe 2660 PST has 9.5x20 fronts and 14.9x28 rears......thats perfect.
So why in the world is the 2660 HST drop back to 9.5x16 fronts and 14.9x24 rears......that puts it at basically the exact same machine as my current MX5100....only a few hundred pounds heavier. (3800lbs vs 4100lbs)
I dunno but I'll find out about the tires.
Don't give up hope yet.
   / Bigger HST machines. #72
You want a higher HP hydro get one;
New Holland
Bidirectional™ Tractor
105 PTO hp
TV6070
8 range power shift hydro.
So pea on those puny 3 manual shift range hydros go 8 range with a button power shifted with the infinite hydro.
You can get a 3 point and pto on both ends.
They are not made new at this time as they stopped at tier 3 emissions,
so get a good used one and do you mowing.
Probably stopped because no one bought them....
   / Bigger HST machines. #73
The last I heard it was down to 250-500 per year so it didn't justify the remodel to meet tier 4 emission.
Plus the early ones did have issues at 6-10,000 hours with the hydros and drives.
Then they were expensive, a conventional powershift with a left hand reverser could do every thing loader wise the bi directional could.
Then the big triple mowers were coming out and the TV's didn't have enough HP to run triples at high speed.
   / Bigger HST machines. #74
LD1, here are 3 options:
1) Fendt , ivt and covers the speed range you specified. The 200 series starts at 79hp, about what you want. I don't know if the front axle suspension is avalible in this series. I have driven larger Fendt tractors and the Vario gearbox ( 3 speed x hydro, computer controlled so you don't notice the range shifts)is very similar to an HST. 2 european members have also sugested you look at Fendt.
2) Antonio Carrea tractors. low slung steep terrain tractor in hydrostatic g/box AND 74hp. The wide tyres on this model should improve comfort and satify your HST and power requirements. There is also a new release model not shown on the website with 99hp.
3) Take a hard look at CURRENT IVT type transmission, and TEST on some customers properties to get an accurate idea of the pro's and con's.
4) Query, is having 2 sizes of mower a practical option?
Good Luck
Good Luck
Haven't even considered fendt. They don't have a strong presence in my area or dealer network. But I am certainly open to exploring them as an option.
No a second mower of a different size is not an option. 8' is the sweet spot for trailering based on length and width. I don't have physical means to haul a rig over 24' total length and about 10k pounds. Hard to justify a tow behind batwing when 90% of the work is under 5 acres
My MX is a perfect size machine for what I want. I only long for larger 20 or 24" fronts like the 5000-series Deere's or small M Kubota for a smoother ride over rough horse pastures or occasional groundhog hole. Of they made a 5065-5075 Deere or Kubota m6060-m7060 in a HST I'd be all over it.
I don't want an 8000# bare tractor. I don't want to be too big and cumbersome to loose the smaller jobs that comprise 90% of my work.
   / Bigger HST machines. #76
I didnt really think I would have to spell out the exact detail of how I use the machine.
I asked a simple question.....and the fact that "gear" was not even mentioned in my original post.
Was met with nothing but everyone trying to convince me that HST is bad and that I should switch to a shuttle when that was NOT even the topic of discussion. I could care less what other people think is a better choice or what they prefer. I know what I want plain and simple.....and nothing holds a candle to HST. So I just wish everyone would quit the BS gear vs hydro debate. This has got to be as stupid and childish as a couple of kindergarteners arguing about green vs orange
I believe you. I used to mow 7 acres at my old place. I mowed it for a few years with a full sized utility tractor with 8 speeds forward and two reverse and a 6 foot finish mower, then for a few years more with a HST equipped tractor with a 5 foot finish mower. Without a doubt I could finish mowing MUCH faster with the hydro tractor with the smaller mower. The reason is because of the terrain and the trees to mow around. In my opinion you cannot beat a hydro for such a mowing task. Just like in my opinion you can't beat a geared tractor for plowing a field.
   / Bigger HST machines. #77
   / Bigger HST machines. #78
I absolutely love the Kubota MX series with the HSt transmission, but I could see the need for some 65 to 85 horsepower tractors with an HSt for loader work. I'm thinking hay tractor, grapple tractor.
My mx5200 hst is the tractor of choice for numerous tasks around the farm, but it's too small to be the feed tractor. You need a lot more machine to slog around muddy fields carrying hay bales (round) to the cows.
If I'm still at my in-laws farm when an 80-90 hp hst is available that will be my next tractor-maybe. I still need a tiny hst for yard work. I might get a 25hp hst first. But my fil already has all the geared tractors I'll ever need. Not going to be getting any more of those regardless of how efficient people say they are.
  • Good Post
Reactions: LD1
   / Bigger HST machines. #79
The British IH tractors came in manual and hst. We had a new 784 loader with manual when I was a kid in early 80's. It had a tranny issue off the lot, and because dealer had to split it and get parts in from England (to Canada) they lent us the HST version for a couple months. Dad still talks about the heat theat it gave off when doing field work.... Says he is amazed that my younger sister was ever conceived after using it to work the land. He said he could believe the difference when we got our manual back for heat and pulling power. You straddled the tranny on the 784s (pretty common then), so tonnes of hot oil pumping right there.
I just bought a Bobcat ct2035hst, for our acreage, and he ranted to me not to get the HST... I think he was having flashbacks. But on a hobby farm, I won't be working the land just some chores, loader work, snow plow etc, so HST is right for me.
Anyway, thought this story may shed some light on why big tractors don't us HST.
   / Bigger HST machines. #80
The fact is that gear tractors are going away. Maybe not soon but they are going to fade away just like manual transmissions in vehicles. first it was cars and pickups. Now getting a stick in a semi is getting harder. The old farmers are dying off and the younger ones taking over are more open to not dealing with shifting or clutches. Even power reversers are going to be mated to some sort of stickless transmission.
Let's face it. Gear was king because they were cheap and mostly bullet proof. Nobody put a computer into a tractor. Operators just expected to spend the day pushing in a clutch and shifting gears. Lots of things have gone by the wayside. Manual windows in cars and AC being optional. We as consumers have grown accustom to spending more money. I expect in 10 years we'll see a form of hydraulically controlled automatic shifting transmission that will operate just like HST in the 50hp to 100hp tractor range. You'll just control the speed with a pedal, like HST, or a lever. It'll be independent of engine speed so the PTO can be ran at speed without impacting tractor speed.
It just makes sense since driverless vehicles are slowly becoming a thing. That also is going to doom manually shifting gears.
  • Good Post
Reactions: LD1
2016 Chevy Traverse SUV (A56859)
2016 Chevy...
MONTANA MOUNTAINEER 5TH WHEEL CAMPER (A52708)
MONTANA...
2018 Freightliner M2 106 Medium Duty AWD Altec AA55 56ft Insulated Material Handling Bucket Truck (A55973)
2018 Freightliner...
2025 JMR 66in Single Cylinder Brush Grapple Skid Steer Attachment (A56857)
2025 JMR 66in...
golf cart (A55787)
golf cart (A55787)
2016 FREIGHTLINER CASCADIA (A58214)
2016 FREIGHTLINER...
