Rear Finish Mower Big Bee 60
/ Big Bee 60 #1
jrm1966
cottontown,TN
mahindra
Need some advice on mower. Mahindra 2216 w/loader and a Big Bee 60 finish mower. I am cutting my yard , about a half acre, and when mowing sometimes the mower slows - PTO starts dropping - and it will kill the engine if I don't push in the clutch . Don't seem to be scalping and the yard is basically flat with high places just like all yards I guess.
I keep thinking it should stay at speed even if I hit high spots and scalp the dirt up but not that familiar with tractors and attachments. I have the spacers out so as to cut the grass short and have cut also with one half inch spacer and still had same problem.
Any advice for newbie. I hope it ain't a problem with tractor. I kinda like it.
Thanks. JR
/ Big Bee 60 #2
Big Bee 60
Might want to consider adjusting your ground speed and try a lower gear. Is this grass you are cutting and what kind? I know bermuda will slow a push mower due to its long runners.
You also may want to check the following:
1. As PTO slows is there an odor indicating something is hot?
2. Consider checking the mower blades for a sharp edge.
3. Consider checking the mower belt(s) for correct tension.
Know if blades are dull or installed backwards this will cause a tractor to stall. Even coming directly from a factory. Would not be the first time something was installed backwards. Just verify mower rotation and cut edge on blade(s).
/ Big Bee 60 #3
I don't know what the HP requirements are for finish mowers but rotarty cutters are 5 HP per foot. You might be right at the max your tractor can pull. tractordata shows your tractor has 17.5 PTO (gear) HP, think I saw in another post where you got a gear tractor. Slowing down might be the best bet.
I have 25 PTO HP and run a 6' rotary cutter. My tractor will bog down going too fast or in tall, thick grass.
CATERPILLAR PC306 PLANER (A65053)
CATERPILLAR PC306...
2019 KENWORTH T680 (A67714)
2019 KENWORTH T680...
2011 FOREST RIVER T/A CARGO TRAILER (A67714)
2011 FOREST RIVER...
2018 MACK LR GARBAGE TRUCK (A66091)
2018 MACK LR...
UNKOWN NATURAL GAS GENERATIR (A67714)
UNKOWN NATURAL GAS...
2024 Chevrolet Camaro Coupe (A66738)
2024 Chevrolet...
