BH90 grease zerk trouble
/ BH90 grease zerk trouble #1
5030tinkerer
Iowa
Kubota GL3830/GL5030
Is anyone aware of a grease zerk tube extension?
My 2003 model BH90 backhoe has a grease zerk pointing straight up right at the left-right pivet point. Trouble is, the zerk has severely limited vertical clearance - even a 90° adapter is ineffective at getting in to grease this fitting. /forums/images/graemlins/frown.gif I have successfully used a hose in place of my rigid grease gun tube, but even then things were way too tight and I was stressing my hose extensively. I tried putting in a 45° and a 90° zerk to replace this one, but since the zerk was counter-sunk to begin with, this didn't allow the necessary clearance. What have others done?
Kubota L3830 HST with BH90 backhoe
/ BH90 grease zerk trouble #2
There is a "needle connector" available at any full fledged parts store that slips on your gun. The needle will depress the ball in that trouble zerk. It does require constant pressure against the zerk (2 hand operation). But hold on, there are probly better ideas than mine. /forums/images/graemlins/crazy.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/tongue.gif
/ BH90 grease zerk trouble #4
I just recently bought one of the needle adapters for my grease gun to grease my impact wrench. I got mine at Northern Tool and they had about a half dozen different styles. The cheapest and smallest one, about $3, is probably the easiest to use and is the one I bought.
/ BH90 grease zerk trouble #5
Yes I am aware of it. I also tried the 90 like you. I finally screwed off the end of my old grease gun and went to the hardware store and bought a small metal L from the plumbing area. It works, tight but it works.
/ BH90 grease zerk trouble #6
THis should work, it is a 90deg fitting..just slide it onto the grease zerk.
90deg fitting
</font><font color="blue" class="small">( Yes I am aware of it. I also tried the 90 like you. I finally screwed off the end of my old grease gun and went to the hardware store and bought a small metal L from the plumbing area. It works, tight but it works. )</font>
This is exactly the type of solution I was looking for! /forums/images/graemlins/smile.gif I had tried the 60° zerk, the 45°, and the 90°, all to no avail. /forums/images/graemlins/frown.gif
I also now own the right angle attachment mentioned by wushaw and tried it - no dice. I have to admit that I own the needle fitting that Bird mentioned, but wasn't at all sure how to use it. Thanks to FredG, I now have an idea.
I'll head over to my friendly Ace Hardware and see if they have a fitting that provides the vertical clearance I need. I take it that you just inserted their fitting where the zerk was and attached the original zerk to the hardware store add-on?
Thanks for all the replies, guys. I appreciate it about as much as you likely know. I have been a lurker for quite some time here - now that I've posted I'm even more of a believer in TBN!
/ BH90 grease zerk trouble #8
Can you post a picture? I am having trouble picturing why you have room to put in a L but not enough room to use a 90 adapter on the gun. I have a different one than what was posted.
/ BH90 grease zerk trouble #9
Here is the thread that shows what I'm talking about. The metal plumbing (or gas?) L worked because the L is shorter. /forums/images/graemlins/smirk.gif
The 90deg fitting did not work for me. I think it had to go up a little to get over the cylinder but not so much that it hit the top, or I could not hold it on and pump... it's been a while. Anyway the L fitting was about 50 cents.
/ BH90 grease zerk trouble #10
AAAHHH I see what the trouble is now...it is a recessed zerk fitting not allowing the 90deg slid on fitting but will allow a 90deg needle fitting but will allow a 90deg needle fitting like one on this page, just scrol down to the bottom.
Other fittings
Or do what Don did /forums/images/graemlins/grin.gif
/ BH90 grease zerk trouble #11
The 90 that I have was picked up at Champion Auto and looks like it would work on that. The adapter snaps on/off the end of the hose fitting and will reach down about an inch or so. The adapter was about $5 or so.
Fork Extensions (A61572)
Fork Extensions...
2021 Ford F550 4X4 Service Crane Truck (A62613)
2021 Ford F550 4X4...
1986 CATERPILLAR D4H HI-TRACK CRAWLER DOZER (A64279)
1986 CATERPILLAR...
2014 Massey Ferguson 8650 Tractor (A63111)
2014 Massey...
72'' SKID STEER BUCKET (A61572)
72'' SKID STEER...
John Deere 4520 (A60462)
John Deere 4520...
