BH77 Grease Points?
   / BH77 Grease Points? #12
beckmurph,
As we used to say when I was drivin' longhorns down 'round Saragosa, it takes a mighty big man to admit he's wrong. I was wrong when I addressed you as "beckworth". I'll meet you out on the street at high noon to settle this :c)
bumper
   / BH77 Grease Points? #13
Beckworth,
On my BH77, there are no zerks (even at the end or underneath or connected with hoses :c( , nada.
I suppose that may be just one of the differences between a construction grade TLB and a tractor with an add on hoe.
   / BH77 Grease Points? #14
Taken out of context, one might deduce that the BH77 has no zerk fittings or is not otherwise "heavy duty" enough for it's size and intended purpose. That would not be the case. All other lube points on the BH77 have zerk equipped pins, save those on the swing cylinder trunnions.
It's a valid point that there will be major differences between "construction grade" equipment and that intended for less heavy duty applications. Which is not to say that much of the consumer grade equipement is not more than up to the task.
Well, with the possible exception of all those little green tractors (snicker :c)
bumper
2018 CATERPILLAR 299D2 SKID STEER (A51242)
2018 CATERPILLAR...
2011 TROXELL 140BBL TRIAXLE VACUUM TRAILER (A50854)
2011 TROXELL...
2015 F-550 Bucket Truck. (A51039)
2015 F-550 Bucket...
2012 Toro Greensmaster 1600 Walk Behind Mower (A48082)
2012 Toro...
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
2007 Volvo VNL Truck Tractor (A51039)
2007 Volvo VNL...
