BH77 Grease Points?
/ BH77 Grease Points? #1
MFortie
Member
How many grease points are there on the BH77?
I counted 21 this time around but swear I've found 22 in the past! :)
Thx
Mark
/ BH77 Grease Points? #2
I count 22 on my BH77.
The two boom swing cylinders have only one grease fitting (on the rod end). The trunnions, where the swing cylinders mount, don't seem to have any grease fittings or lubrication points at all. I realize there's not a lot of movement there, but there is some. Am I missing something here? Shouldn't these points be lubed too?
bumper
/ BH77 Grease Points? #3
It is a game Kubota plays......see if you can miss a zerk and it will be the one that fails! I have a BH65 and I have the same problem especially after a long winter!
/ BH77 Grease Points? #4
Book says to hit them every 10 hours....man you are right there are a billion of them.
/ BH77 Grease Points? #5
bumper
This is a bump for my question . . . anyone with a BH77 know what's up with no apparent grease fittings for the swing cylinder "trunnions" (where the cylinder mounts to the hoe frame)? Anything I can't grease I worry about.
bumper
/ BH77 Grease Points? #6
I have the BH76 and it does not have grease fittings for the swing cylinder trunnions. I wonder the same but never remember to ask my dealer.
/ BH77 Grease Points? #8
My B26 has 28 but 4 of those are on the hydraulic thumb, so normally it would be 24. I have two on the back of the swing cylinders. They are accessed from extended nipples that are just under the platform and have tubing running back to the trunnion connections. They aren't easily seen if you aren't looking for them. I think you guys should look closely as there should be grease fitting for the backs of the swing cylinders just like on mine.
/ BH77 Grease Points? #9
Well, there is no movement in the trunnions. I looked at mine this afternoon. The cylinder rods move out and back in a straight line. No movement in the trunnions. :dance1:
/ BH77 Grease Points? #10
Beckworth,
No offense, but that is not correct*. If you look at the swing cylinder you'll note that the rod end is attached to an arm sticking out a 90 degrees to the boom arm when the boom is "centered". As the swing cylinder extends or retracts, that arm transcribes an arc, and in doing so, the cylinder will move, rotate, a few degrees on that trunnion. No, it's not a lot of movement, but it IS rotational movement at the trunnion, and as such there has to be a bearing surface, bushing or bearing or whatever. On my BH77, there are no zerks (even at the end or underneath or connected with hoses :c( , nada. So, it might be designed as a dry bearing surface I reckon.
*Disclaimer - it is possible, of course, to design a boom swing mechanism that requires no movement of the ram cylinder, though those won't generally be mounted on trunnions and will be fix mounted. The ones I've seen use the ram to pull/push roller chain and that takes care of what would otherwise require some radial motion.
bumper
/ BH77 Grease Points? #12
beckmurph,
As we used to say when I was drivin' longhorns down 'round Saragosa, it takes a mighty big man to admit he's wrong. I was wrong when I addressed you as "beckworth". I'll meet you out on the street at high noon to settle this :c)
bumper
/ BH77 Grease Points? #13
Beckworth,
I suppose that may be just one of the differences between a construction grade TLB and a tractor with an add on hoe.
/ BH77 Grease Points? #14
Taken out of context, one might deduce that the BH77 has no zerk fittings or is not otherwise "heavy duty" enough for it's size and intended purpose. That would not be the case. All other lube points on the BH77 have zerk equipped pins, save those on the swing cylinder trunnions.
It's a valid point that there will be major differences between "construction grade" equipment and that intended for less heavy duty applications. Which is not to say that much of the consumer grade equipement is not more than up to the task.
Well, with the possible exception of all those little green tractors (snicker :c)
bumper
2007 KOMATSU PC35MR-2 TRACKED LOADER EXCAVATOR (A59914)
2007 KOMATSU...
Pat's QH and hydraulic top-link.
Pat's QH and...
EZ Trail 3400 Gravity Wagon (A66285)
EZ Trail 3400...
John Deere 750C Dozer (A66285)
John Deere 750C...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
Genie S40 Boom Lift (A64047)
Genie S40 Boom...
