BH76 Bent dipperstick piston anyone?
/ BH76 Bent dipperstick piston anyone? #1
Bing187
Bronze Member
Rehoboth, Massachusetts
Kubota B3300SU
Hello all,
Digging a trench 2 days ago with my B3300SU, equipped with BH76. Have used the heck out of this machine, with overall great satisfaction....
Trench was for an electric line for pool filter, only about 18" deep, very bony ground. Was pulling towards machine, using dipperstick to keep bottom of trench flat, pulling right up to machine and about to move tractor forward to extend trench further. Picked up scoop of dirt/ rocks, dumped, and when I went to extend dipperstick, it was sluggish, didn't want to extend arm (retracting piston.)
Hopped off, and looked at piston from side. Bent about 1/2". Don't remember hitting anything particularly hard when stick was all the way in (piston all the way out), but... Here I am. Have already ordered new rod. Tube and seals look fine when gland nut taken off, seems the actual chrome rod is only part that got tweaked.
Strange to me that with all the digging I have done with it, that it would bend on something relatively benign. I've dug some relatively big rocks out of the ground with it, with no probs.
Reason I'm asking here is wondering if there could be some other underlying problem that would cause this. Already checked relief valve, opens at correct pressure. General opinion at Norfolk power and other equipment owners that I've spoken to is that it's a fluke, caught a rock when piston was all the way out, or maybe caught a rock, slipped off and hit another rock, and leverage/ momentum bent it. Also wondering if anyone here has had same prob with this machine or similar, and what cause was. I don't begrudge fixing it, but I don't want to put a $400 part in and have it do the same thing again. Also looked at boom and dipperstick.... Nothing else seems bent or out of alignment at all.... just the bent rod.
Thanks in advance for any response or advice.
Mike
Well this sucks. UPS just delivered overnighted part, and it's different. Length and diameter of rod same. Machined surface (diameter) for piston 1/4" smaller on new part, machined surface 1/2" shorter(length) on new part. Coarse threads on old part, fine threads on new part. WTF. Dealer trying to sort it out now. Sure glad I paid the extra to overnight.... Now it will be 3 days anyway. REALLY need to get stuff done right now, on vacay from work til Tuesday, had a TON of stuff I needed to get done b4 I go back to work. Never fails.....
Problem solved. Dealer just called. Apparently, there are 2 serial #'s for BH76. Older one and newer one. Complete cylinder assy part # is same for both, but upon further investigation, rod part # is different for old/ new. At least it didn't turn into a search. Very apologetic parts guy, overnighting new one, waiving extra $ for overnighting original one. Sigh. Hopefully tomorrow will be a better day.
I feel like I'm talking to myself here. Good therapy. lol
2014 Jacobsen AR3 3-Deck Commercial Rotary Mower (A59228)
2014 Jacobsen AR3...
2012 International (A59230)
2012 International...
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
2019 JOHN DEERE 850L LGP CRAWLER DOZER (A60429)
2019 JOHN DEERE...
2010 LAREDO 5TH WHEEL (A55745)
2010 LAREDO 5TH...
MASSAGE CHAIR (A58214)
