BH75 Piston broke, twice! Design problem??
/ BH75 Piston broke, twice! Design problem?? #41
I have the tendency to back up too close to a stump and wind up having to dig (and curl) a bit with the dipperstick fully extended. I'll keep that in mind.
Your dealer isn't doing you right. /forums/images/graemlins/mad.gif With all these problems, and having their engineers clear you of overworking the hoe, they should be coming through with weekend loaners. Keep after them. I've seen many threads on several boards and big problems like this almost always get solved by "moving up." The squeaky wheel gets the grease.
OK guys, here is a link to the clip. It is 10 MB so I can't attach it.
http://web.utk.edu/~hines/tractor/backhoe.mpg
Watch the dipperstick cylinder bend when the bucket curls. Do this several times and the piston breaks due to fatigue failure.
I called Kubota again this morning, they pushed me up the line, but all I got to talk to was the recording machine. I've hit my limit. My stance is currently, pick it up and give me a loaner or pick it up and give me my money back.
This should prove it is not my fault, it is their fault, so they should bend over backwards to make me happy. The line that "This is a new product" should not be uttered. They should not put a product out before fully tested.
/ BH75 Piston broke, twice! Design problem?? #43
The clip doesn't work. /forums/images/graemlins/frown.gif
EDIT: Nevermind, problem on my end, now fixed.
/ BH75 Piston broke, twice! Design problem?? #44
</font><font color="blue" class="small">( Well, if you just extend the bucket back down, you would have a lot of leverage against the dipperstick cylinder. The leverage from the curled bucket may be enough to bend the dipper stick piston. I don't know whether to test this hypothesis or to try to avoid it. )</font>
The video seems to confirm your earlier theory. At about 2 seconds into the 12 second video clip, its pretty clear that as you curl the bucket, the dipperstick piston bends quite a bit. Its too bad you weren't around when Kubota's QA engineers came out. Seems like it would have been pretty easy for you to demonstrate how to get the piston to fail.
I'd be frustrated too if I were in your shoes. Hopefully Kubota will come through. If you have a name and number for the QA folks, I'd call them as well. The squeeky wheel gets the grease, and you definitely have a very legitimate gripe in my mind.
/ BH75 Piston broke, twice! Design problem?? #45
You'd think they'd come right out with a brand new replacement BH and take the defective one to research why it failed? /forums/images/graemlins/confused.gif
/ BH75 Piston broke, twice! Design problem?? #46
Now that you have shown the movie, It is easy to see what is going on.
In the film all three cylinders are putting pressure on the teeth. The bucket teeth are turned at the worst possible angle to dig. The manual should have a series of pictures that demonstrates how to angle the bucket to dig. By angling the bucket the way that you are, you are putting even more pressure on the entire backhoe, because as you are rotating the bucket to dig, you are in effect lifting the tractor and backhoe. When this lifting doesn’t happen, that is when the cylinder bends. The intensity of the situation is far less, the further the bucket is from tractor, because several of the angles change. This is the way it is sometimes when a new person starts using a backhoe. If you keep it and continue to get experience and listen to what I said above, the problem will go away. I don’t mean to be cutting you down or being mean in anyway, just that that is the way it is sometimes.
I am sure that I will get a lot of flack, flaming etc. There will even be some that will say that no matter what Kubota should take care of it. There will also be some that will say that no matter what, It shouldn’t have ever happened and wouldn’t have if the relief worked or the engineering was right or that the metallurgy is right. Well guys, these small hoes cost anywhere from 5k to 10k. They are made to where they will do the job for most people and cost the manufacture the least. Yes, they could build a hoe that wouldn’t do this under any circumstance, but how many people would buy a hoe for a compact that cost in the 20k range? There is always a weak link in everything. More money and over engineering would just move the point of failure. Kubota will try to make you happy. They will replace cylinders and they may change out the relief valve
/ BH75 Piston broke, twice! Design problem?? #47
I don't know where to start.
Kubota should make this right.
The dirt shown in the video is soft loam, and should be easy digging.
Of course there is pressure on all 3 cylinders, that's why a backhoe works. Imagine how poorly a backhoe would work with pressure removed from any one cylinder.
Backhoe manual recommends using bucket curl for difficult digging.
It's ok to dig close to the tractor.
Why are you making excuses for Kubota when there is an obvious problem.
Guy
/ BH75 Piston broke, twice! Design problem?? #48
<font color="blue"> Why are you making excuses for Kubota when there is an obvious problem. </font>
Because it is more than likely more operator inexperience than anything being wrong with the hoe. This is not just Kubota. I have seen this happen on almost all brands of backhoes. Once in a great while it will be a relief that is causing the problem, but most of the time, the problem goes away as the operator becomes more experienced.
<font color="blue"> Kubota should make this right. </font>
I am sure that they will try.
/ BH75 Piston broke, twice! Design problem?? #49
What does the manual say? Is there anything in there that says you can't do this?
/ BH75 Piston broke, twice! Design problem?? #50
This is not normal... Kubota must do something.
I never knew how it failed until I reviewed the tape. In bends in line with the user' sight so it is not seen until you extend and hear it squeek.
Just got a call from Kubota. The engineers are bringing up a new backhoe tomorrow and swapping mine out. They said they tested this one thoruoghly (sp?). Lets hope this one works better, it is supposed to rain this weekend, but if it is dry, I'll post my experiences.
I really love the tractor, it is a real workhorse, I should post more pictures of theheavy work I've done. I just need to get this ditch dug.
Thanks to everyone for the support, even those who want to make me a better operator;)
/ BH75 Piston broke, twice! Design problem?? #53
One question. Have you noticed bubbles in the fluid or is it white?
Bubbles? Where and when do I look? THere is a sight glass but I've never look at it while operating.
/ BH75 Piston broke, twice! Design problem?? #55
This is all about a poorly selected cylinder size/strength for the application. A machine for this market should not be capable of self-destructing like this without EXTREME abuse (which is not shown in the video.).
IMHO.
/ BH75 Piston broke, twice! Design problem?? #56
I can't get it to work. Any suggestions? I just get the quicktime icon. I have quicktime, but when I right click on the icon it shows the plug in which may be the problem.
Any help would be appreciated, I would like to watch the movies too /forums/images/graemlins/laugh.gif besides I just popped some popcorn /forums/images/graemlins/grin.gif
/ BH75 Piston broke, twice! Design problem?? #57
I had to download it and run it as an application, not a plug-in. Right click the link and do a "save as". Then double click it on your local drive.
You may try right clicking on the link and choosing "save target as" this downloads the file to your computer. At that point you can use windows media player to open/play it.
Hope that helps.
/ BH75 Piston broke, twice! Design problem?? #59
Mine did the same. Go to your temporary internet files and copy the file to another folder then access it. Worked for me, don't know why.
Video pauses about 1/2 way through, but the bending is shown.
/ BH75 Piston broke, twice! Design problem?? #60
I don't know if you could see bubbles in the sight glass or not. It they are real bad you can see them on the dip stick if you check just as soon as you turn the tractor off. You can also use a suction gun and take some out of the fill plug or drain some out of the bottom. If it is hyper aerated it will disable the relief valve, at times.
2022 John Deere RD40F Draper Head (A63111)
2022 John Deere...
2004 VOLVO VHD TRI/A CEMENT MIXER TRUCK (A59911)
2004 VOLVO VHD...
2008 Freightliner Allegro Bay Class A Motorhome (A61574)
2008 Freightliner...
26ft Mobile Spray Foam Trailer (A61573)
26ft Mobile Spray...
2017 Jeep Renegade SUV (A61574)
2017 Jeep Renegade...
Challenger 65E/75E/85E/95E Tractor Parts and Service Manuals (A63117)
Challenger...
