Backhoe BH75 Backhoe problem on B3030
/ BH75 Backhoe problem on B3030 #1
Bob53
SW/PA
B3030
About a week ago I was trenching with the hoe past a tree.
I heard roots breaking as usual, but then unfamiliar clink. 10 seconds later the rod came flying out of dipper clylinder. It actually cracked in half in the cylinder and came out then.
It is at the dealer now and hopefully is going to be warranty.
I'm just wondering if I'm pushing it a little too hard for this size hoe and could happen again? The roots where breaking and where not that thick. I know if its to thick it just would not move, Is this limit a setting that might have been set too high?
Are the Woods hoes more sturdy, hopefully this was just a fluke.
/ BH75 Backhoe problem on B3030 #2
There seems to have a been a streak of people having problems with their Kubota backhoes here on TBN over the last few months. Hope this isn't an indication of things to come with my BX23 /forums/images/graemlins/tongue.gif . I can't believe that you were doing anything so wrong with the hoe as to cause something like that to happen. If the hoe was properly designed you should just hit the relief valve on the hydraulics before you get to the point where you do any real damage.
Oh, so there is a releif valve that limits digging pressure?
I guess that will check it when rod is replaced. Do you know if relief valve adjustable?
/ BH75 Backhoe problem on B3030 #4
Bob,
I broke the dipperstick piston on mine in much the same way. It didn't acutally come out of the cylinder, but it happened while digging out elm roots. I'll be renting a Caterpillar 420 to get the last 5 stumps--the first two took a whole week each, and I'm not spending a month of back-breaking labor in 110 degree heat indices getting them out.
Anyway, mine was fixed under warranty, so yours should be too. Just make sure the replacement piston is thicker than the original.
/ BH75 Backhoe problem on B3030 #5
I just bent the curl cylinder on my BH75 the other day.
Dealer said the new cylinders are 2mm bigger in diameter and Kubota knows of the problem and are working on a permenant fix.
The BH75 and BH90 are new implements and apparantly the engineer misplaced a decimal point somewhere on the cylinder capacity.
/ BH75 Backhoe problem on B3030 #6
<font color="blue"> </font> "the engineer misplaced a decimal point"
<font color="black"> </font> Are they still using slide rules over there? Or maybe they are sub-contracting work to China.
Thanks,
Sounds like its obvous need thicker dia rod, I guess long as they warranty till they get fix. At least i can talk to dealer and see if he is up on this.
/ BH75 Backhoe problem on B3030 #8
On the BH90 there is an adjustable relief for the boom, dipper and swing on the valve stack. The stabilizers and bucket curl rely on the system relief. At least thats what I remember from looking at mine. If you look at the valve stack you can see the relief housings which sit above and below the main spool sections. I suppose it's possible that the spools share the reliefs, so I could be wrong in my assumptions about the system relief being used. I don't have a service manual for the BH90. Your BH75 may be similar.
I have had to reseal the cylinders (myself) but have not broken or bent any. I am in talks with Kubota about making me whole. The ball has been in their court for a week. I'm waiting for the 'phone to ring.
MY BH90 is currently between repairs.
My impression of Kubota hoes is that they are powerfull tools that will not last very long. I don't think 120 hours use and then having to reseal the cylinders is indicative of the high quality product that they charge you for at purchase time.
JMHO based upon my direct experience.
To be honest there must be some happy customers. We just tend to comiserate with the unhappy ones.
All the best,
Martin
/ BH75 Backhoe problem on B3030 #9
</font><font color="blueclass=small">( The BH75 and BH90 are new implements )</font>
That's true of the BH75, but is it true of the BH90 ?
It seems like I've seen alot of posts on the BH90 over the last year or so ...... is my memory faulty ?
/ BH75 Backhoe problem on B3030 #10
The BH90 was introduced at the same time as the Grande L **30 came out. I believe it was 2003 model year.
Just talked to the dealer and he told me he is going to put a new clylinder assemblyon it but did not hear about there being problem and a larger dia coming out. Although they had to get the complete assembly because out of stock on rebuilding, so i guess thats good. So I'm going to check with kubota down the road to see if anything has been extablish on this. Forgot to ask about making sure relief valve was working properly, will have to call him back on that.
thanks for you're help
/ BH75 Backhoe problem on B3030 #12
I have the 75 on my 2630. I better check with my dealer to see if there is an upgrade before anything happens.
Bob, Keep us updated.
will do!
I e-mail the kubota Rep thru there web site yesterday and he called me today to tell me that he called my dealer that had my hoe to make sure he replaced the broken dipper cylinder with the the updated cylinder that has a bigger diameter rod than it was shipped with orginally, so this is less likely for rod to break in half again. So it does look like this is a problem with the BH 75 and the bigger cylinder should make it less likely to happen again. I imagine they are only upgrading broken ones, not sure. I did ask if any of the other cylinders on the hoe where in need of thicker rods if broken and he said no, only the dipper clyinder. I don't want to create painic, because i was probly pushing the hoe to the limit from digging roots, but if anyone else's dipper cylinder rod breaks on the BH 75 I'd make sure i'd mention the update on the clylinder.
/ BH75 Backhoe problem on B3030 #15
It would seem like if it ain't broke it won't get replaced because you busted a dipper cylinder and I bent a curl, so both are suspect to bending or worse.
/ BH75 Backhoe problem on B3030 #16
Bob53, I have a B3030 and a BH75. I used the backhoe for many hours so far and... nothing /forums/images/graemlins/confused.gif , no bending at all. I know that some TBNers bent cylinders. What was the backhoe's position when it happened? I wonder if I'm lucky or if I simply don't make that killer move.
Stef,
When the dipper cylinder broke I was trenching past a tree, It was not even hanging up, so roots where not that big, rod was not fully extended maybe only halfway out. I usually curl the bucket while pulling up with dipper cylinder, seem to get the most power that way. So that may be the killer move. Rod then cracked and just came out the the clylinder. It was pretty warm, i was about 4hrs in to this long trench so as said worse case.
Yes I imagine since its a new hoe, if they get a lot of failures in one picticular cylinder they just replace with bigger cylinder, probly same with the curl cylinder , they are just not going to admit. So in a way I'm glad it broke now rather than 2+yrs down road and not warranty. I Just have to stress the curl cylinder to get it replaced since that seems to be week link too, just kidding. Its machinery and it breaks so I guess it will always be something, hopefully not often though. Love everything about the tractor though, does a lot for its size.
/ BH75 Backhoe problem on B3030 #18
I just picked up my replacement cylinder and it is the same size as the bent one, I was told that only the dipper cylinder has been increased in size.
I had a Bradco 3265 on a B7500 for 2.5 years without any failures and I am not doing anything different with this BH75.
I still have ten months to break or fix this one.
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
2016 Ford Fusion Sedan (A64557)
2016 Ford Fusion...
UWS TBS-69 Truck Bed Tool Box (A64556)
UWS TBS-69 Truck...
Bestway 750 Sprayer (A66285)
Bestway 750...
2018 JOHN DEERE 844K-III AG HANDLER WHEEL LOADER (A65053)
2018 JOHN DEERE...
GARDNER-DENVER TRIPLEX PUMP ON SKID (A65643)
GARDNER-DENVER...
