BH65 backhoe on B2620 3rd function...
   / BH65 backhoe on B2620 3rd function... #1
11B2620
Rockford, MI
B2620 and BX2200
The joysticks on the BH65 have a set of valves underneath them.... Could I take off the endcap, put another valve there, use longer bolts, bolt the endcap back on and use the new valve as a 3rd function?
   / BH65 backhoe on B2620 3rd function... #2
Without looking, I would say quite likely, you would have to buy another OEM stack valve of that hoe series, and determine which one you want. Whether your existing cover will allow it is something to look at. If there was lots of room, you may even get enough to shove an extra valve in the center and move the joysticks 1/2 inch out each way, and open the center stabilizer slots to one big one to allow three levers. You'll have to do some precise measuring before contemplating.
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A56436)
Galvanized...
IRET13 ELECTRIC TRICYCLE (A58214)
IRET13 ELECTRIC...
2017 Mercedes Benz GLA SUV (A56859)
2017 Mercedes Benz...
pressure washer, and trailer (A56859)
pressure washer...
Kubota M5-111 (A53317)
208316 (A58375)
208316 (A58375)
