BH65 backhoe on B2620 3rd function...
/ BH65 backhoe on B2620 3rd function... #1
11B2620
Rockford, MI
B2620 and BX2200
The joysticks on the BH65 have a set of valves underneath them.... Could I take off the endcap, put another valve there, use longer bolts, bolt the endcap back on and use the new valve as a 3rd function?
/ BH65 backhoe on B2620 3rd function... #2
Without looking, I would say quite likely, you would have to buy another OEM stack valve of that hoe series, and determine which one you want. Whether your existing cover will allow it is something to look at. If there was lots of room, you may even get enough to shove an extra valve in the center and move the joysticks 1/2 inch out each way, and open the center stabilizer slots to one big one to allow three levers. You'll have to do some precise measuring before contemplating.
RoadTec RP190 (A63118)
New/Unused Quick Attach Rock Breaker (A61166)
New/Unused Quick...
(6) KUBOTA SIDE MOUNT IDR BRACKETS (A62130)
(6) KUBOTA SIDE...
2006 Hypac C530AH Pneumatic Wheel Compactor (A61567)
2006 Hypac C530AH...
New/Unused Wolverine 77in Quick Attach Bucket (A61166)
New/Unused...
UNUSED WOLVERINE PFF3-13-45W UNIVERSAL MAST (A62131)
UNUSED WOLVERINE...
