BH Pics wanted "PLEASE"!!!!!!!
/ BH Pics wanted "PLEASE"!!!!!!! #1
don716
North Georgia
Kubota/ B7500/with 2000 lb winch
BH Pics wanted \"PLEASE\"!!!!!!!
I would like to see your BH in action. I want one so badly but I don't have all the $$$$ I need for one. So until I can get the $$$ I would like to drool over your BH in action. I have a B7500 with a FEL and it would be so neat to have a BH on the back to play( I mean work with) around the house. So I say again "Hit me with your best pic"
Thanks, Donny /forums/images/graemlins/smile.gif
/ BH Pics wanted "PLEASE"!!!!!!! #2
Re: BH Pics wanted \"PLEASE\"!!!!!!!
Donnie, my CK20 is about the same size as your tractor.
Check out my albums to see some backhoe shots.
John
/ BH Pics wanted "PLEASE"!!!!!!! #3
Ok So I rented this one. Makes the one on my bx seem awful small.
/ BH Pics wanted "PLEASE"!!!!!!! #4
Here is the one I own.
/ BH Pics wanted "PLEASE"!!!!!!! #5
Donnie, here's one that I haven't posted to my CK20 Albums pages. I have posted it on TBN before though.
John
/ BH Pics wanted "PLEASE"!!!!!!! #6
The BX23 will pull some pretty big rocks out of the ground....
/ BH Pics wanted "PLEASE"!!!!!!! #7
I'm drooling! I want a backhoe in a bad way ...didn't say I needed one but I sure want one!
Good pics guys; Keep em coming. If you got em, show em off!
Moon of Ohio
/ BH Pics wanted "PLEASE"!!!!!!! #8
Heres a picture digging across my driveway to reroute a spring across into a ditch. I found a 20' very heavy pipe on another piece of my property and decided it would be of better use here.
Mike
/ BH Pics wanted "PLEASE"!!!!!!! #9
This one is after placing the pipe and covering it back up. Notice all the water the pipe took away from my yard?
/ BH Pics wanted "PLEASE"!!!!!!! #10
Here is one of the first stumps I removed. This is the before picture.
Greg
/ BH Pics wanted "PLEASE"!!!!!!! #11
This is the after picture.
Greg
/ BH Pics wanted "PLEASE"!!!!!!! #12
Here is a picture of my BH at work with my "Dump Truck"
/ BH Pics wanted "PLEASE"!!!!!!! #13
Here is a picture of my BH removing a concrete walkway.
/ BH Pics wanted "PLEASE"!!!!!!! #14
<font color="blue"> </font><font color="blue" class="small">( The BX23 will pull some pretty big rocks out of the ground.... )</font> </font>
Jim, what did you do with the rock after digging it out? I can get rocks like that out of my hard, rocky soil (silt/clay...) but, once out, unless they are flat enough to get chains to hold on, I can't get them in the FEL (or even pick them up, sometimes).
Tom
I'm at work now but, will post some pic.'s when I get a chance.
/ BH Pics wanted "PLEASE"!!!!!!! #15
This is a picture of my BH cutting through roots in a cluster of stumps that I removed.
Greg
/ BH Pics wanted "PLEASE"!!!!!!! #16
This is a picture of it lifting the top half of a tree and transporting it to the cutting area.
/ BH Pics wanted "PLEASE"!!!!!!! #17
This is just a picture of it "stretched out".
Hope these help Don,
Greg
/ BH Pics wanted "PLEASE"!!!!!!! #18
When I pulled that rock out I was excavating the area to lay the base for a new driveway. I managed to get it into the FEL - and I have a picture showing it in the bucket. When I get home tonite (at work now) I can post the picture. I have a toothbar on the FEL bucket and I have found that helps quite a bit getting the rocks into the bucket because I can get the teeth under them. It is a pain though to get the bigger rocks into the bucket a lot of the time. I found what usually ends up happening is I keep trying to get the bucket under the rock and get it to roll in - but while I am doing that I am pushing the rock along. If I can get the rock up against a bank of dirt or on the edge of a hole I can usually lever it into the bucket somehow. If you were trying to get a big rock into the bucket on flat ground it is a pain - the rock tends to just keep rolling away.
/ BH Pics wanted "PLEASE"!!!!!!! #19
I've got backhoe pics in my <font color="blue"> CASE </font> and <font color="blue"> BARN </font> Webshots links below. Some of the pics are of my neighbor's BX22 (that I use more than he does /forums/images/graemlins/grin.gif) and a few are of a JD110 that I rented a couple of times last fall.
/ BH Pics wanted "PLEASE"!!!!!!! #20
BH pictures? Is that kinda like looking at girlie magazines??
Here's my BX-22 negotiating a holly tree to make room for the shop.
CASE TR340B SKID STEER (A64279)
CASE TR340B SKID...
2015 FREIGHTLINER MID ROOF SLEEPER TRUCK TRACTOR (A59910)
2015 FREIGHTLINER...
2020 INTERNATIONAL LT625 SLEEPER (A59910)
2020 INTERNATIONAL...
2007 TROXELL 150BBL ALUMINUM VACUUM TANK TRAILER (A63569)
2007 TROXELL...
2016 Case IH Magnum 310 Tractor (A64047)
2016 Case IH...
2024 JCB 35Z (A60462)
