Backhoe Better than a tree spade
/ Better than a tree spade #1
Desert Bred
Goodyear AZ
1998 CKC TS 254 (Fei Dong 295T1)
I used a backhoe to dig a 16' perimeter around a lemon tree, 3' deep.
Tied a cable around the base and pulled a cable through the bottom to cut whatever roots were there
Then wrapped in burlap
Lifted it out with the forks, all in one little root square.
Got over the tree spade idea pretty quickly.
/ Better than a tree spade #3
I just try and dig them out with one scoop using my 24" bucket. Only have a fifty percent survival rate though. Not sure I have the patience to do what you did, but I will remember this if there is a tree I really want to survive. I would dig around it with my 12" bucket. Changing buckets is a royal pain though.
Not sure what you meant about the cable through the bottom.
/ Better than a tree spade #4
After after he dug around the tree there will be dirt directly under the root ball. He pulled the loop of cable through this dirt, from the opposite side towards him, loosening the root ball from the ground.
Pretty good idea too, btw! :thumbsup:
/ Better than a tree spade #5
Didn't the whole thing kind of fall apart when you did that?
No it didn't. Maybe it was the soil, maybe the amount of roots, but i let it sit wrapped in burlap for a few weeks because i had to fix the tractor, watered it and it pretty much stayed intact. The bottom lost a little bit of dirt from the forks going under but for the most part, the tree didn't wither, looks happy and is still out of the ground! In a cube of dirt. Pretty happy about that. Plus, I dont have 3k for a spade or the time to make one. I have a dozen or so to relocate.
/ Better than a tree spade #7
How thick was your cable? What type of soil do you have? Mine is a crap shoot, sandy in one place and clay in another and could be rocky anywhere.
It was a thin cable 1/4. Attached to the teeth of the hoe, at the base, a channel 3' was dug out from the square perimeter where the hoe could pull it through all while maintaining the depth.
Soil here is pretty not sandy at all. Pretty normal soil after 1' down..
Thought to post some better pics.
1- Digging the channel - how the bh pulls the cable under the slab
2- tie down tight
3 & 4 removal
5 - in the hole
Sliding into place is tricky. Have to make the destination hole bigger.
/ Better than a tree spade #10
That seems to work really well, thanks for the post and the pictures really help.
Update: I omitted the cable cutting step, and the removal was just as good.
/ Better than a tree spade #12
My neighbor has an 8' Ponderosa Pine that I can have. I want to transplant it but am afraid I'll kill it. Next Spring I'll try your idea. Looks very time consuming and labor intensive. But I guess not nearly as time consuming as growing an 8' Ponderosa from a seed!!!!
Thanks for the pics, worth a thousand words.
Sure thing. Its not that bad as far as time roughly 4 hr per tree I have about a dozen I'm doing . Good luck !
UNUSED WOLVERINE QC7-26-12.5G QUICK COUPLER 7 (A64281)
UNUSED WOLVERINE...
2014 Ford F-150 Pickup Truck (A61573)
2014 Ford F-150...
2002 Vermeer SC252 Walk-Behind Stump Grinder (A61572)
2002 Vermeer SC252...
YALE VERACITOR 50XV STRAIGHT MAST FORKLIFT (A64279)
YALE VERACITOR...
2023 CASE TR340B SKID STEER (A64279)
2023 CASE TR340B...
2023 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A61572)
2023 ASV RT-25...
