Better Lynch Pin?
/ Better Lynch Pin? #21
Is there anything more secure than this style of Lynch pin to the lower lift arms?
I keep losing them while brush hogging. I'm thinking about using a bolt and nyloc nut, but that would be a pain.
I buy the black lynch pins. They have a lot stronger lock ring. A little more expensive but well worth it. I get them at tractor supply.
/ Better Lynch Pin? #22
I've got the 'regular' versions that get lost, and my high-$ finish mower had the so-called 'locking' style others linked, two of which have disappeared. The cure is a bolt with a 'nyloc' self-locking nut. Considering how seldom I *need* to remove a pin, and how often I have to replace them due to loss, bolts and nylocs are less time consuming. And cheaper.
/ Better Lynch Pin? #23
I bought a pack of 4 locks all keyed the same and keep the key on key ring and a spare in the tool box. I did this after a pin came out. The mower shifted left, caught a 5-6 inch dead tree, pulled idown on me. Before I discovered what was happening limbs were under the clutch and I couldn't get to the key. Tractor finally stopped when FEL hit a tree. Lots of scratches and 4 cracked ribs.
/ Better Lynch Pin? #24
How about a shackle with a pin length and diameter to fit the end?
The pin in some are "captive" and can be tightened securely and alo be loosened fairlly easily.
/ Better Lynch Pin? #27
I went to a Pat's Quick Change setup and grade 8 bolts with nylocks. No issues since, and changing implements is a whole lot easier. They go on sale here annually.
/ Better Lynch Pin? #28
Just use a large washer next to the hitch. Problem solved.
/ Better Lynch Pin? #29
There IS...it's a locking type of Lynch pin. Sorry I don't have a photo. If you use "regular" Lynch pins, orient the pin so that the weeds/grass can't easily grab onto the loop when traveling forward. On that locking style, the loop part has to be squeezed before it can be rotated/released.
/ Better Lynch Pin? #30
See earlier posts. If you ain't lost one, ya ain't trying hard enough.
/ Better Lynch Pin? #31
Perhaps in this specific situation, a pivot pin would be less likely to fall out? They come in all shapes and sizes.
There's also these crazy doo-dads, but I've not a clue what to call them:
That squigly one is called a "Rue pin" or a "ring cotter pin"
I bought some about a decade ago. They work really well if you can remember how to use them.
/ Better Lynch Pin? #32
I lost a few also. Just used a small chain with clips from old dog leashes on them attached the the lift arms and the clips. Still a couple came out but were still with me.
/ Better Lynch Pin? #34
This is one style of a guard to help keep the pin protected.
Another style (pinis inserted the wrong way in this picture )
/ Better Lynch Pin? #36
/ Better Lynch Pin? #38
reidg looks like a very good pin to fix the issue. Also, I just noticed you joined TBN 12 years ago, and you've made a total of 2 posts!
/ Better Lynch Pin? #39
Lucky Dog, the one shown on your text are of poor quality. Bought them and thrown them away. They arr dangerous. Don't buy them, for security reasons. You can't find anymore those quality lynch pin any more. My old tractor still have some of them. They do the job. And, because I have to use the hydraulic bar to lowered my attachment , when I am loaded,,because of a down slope, some times these attachments scrape the soil which cause the lynch clip to pry open. The old ones don't open this way. We dhould be able to find the industrial type uses by machinery fabricant, on their new machineries sold, if that exist any more. Good luck.
2017 Kenworth T680 (A64127)
2017 Kenworth T680...
2016 Polaris Ranger 570 (A62613)
2016 Polaris...
SARLO (A64557)
SARLO (A64557)
2012 DRAGON  130BBL VACUUM TRAILER (A65643)
2012 DRAGON...
International 2000 End Loader (A66408)
International 2000...
Crust Buster 15ft. Grain Drill (A65640)
Crust Buster 15ft...
