best way to spread 5 tons of lime with 3032e
   / best way to spread 5 tons of lime with 3032e #1
Rackluster
Hello. Quick question. I need to spread 5 tons of lime over 2 acres. What is the best way?
Do you think I could pull one of the spreaders that coops rent out? If so, how much lime could it pull too?
The coop will not deliver unless I get a semi load.
I'd like to find a way to get ag lime. I have a 3 point speader but I've heard they will only spread pelletized.
Hoping to get this done on friday. I've delayed it pretty much all summer because I didn't want to buy pelletized.
If I were to buy pelletized how much do you think I'd need? My understanding is it takes less pelletized.
   / best way to spread 5 tons of lime with 3032e #2
1 Ton pellets would be plenty.
   / best way to spread 5 tons of lime with 3032e #3
By Friday?
Hire the guy with the lime truck with spreader. He's in and out in 40 minutes if you chat for 10.:thumbsup:
   / best way to spread 5 tons of lime with 3032e #4
By Friday?
That's the best way. Don't beat up the tractor with one of those big spreaders for that many acres.
   / best way to spread 5 tons of lime with 3032e #5
You dont want to put over one ton per acre per year....if your soil test recommended 2 tons per acre, do it over a 2 year period. Also....the lime needs to be put out a few months before fertilizer for it to work properly, typically lime in wwinter and fertilizer in spring. Our local co-op has a buggy for.spreading if you buy a few tons at a time.
   / best way to spread 5 tons of lime with 3032e #6
40' High Cube Multi-Door Container (A53314)
40' High Cube...
2016 CATERPILLAR 330 FL EXCAVATOR (A60429)
2016 CATERPILLAR...
2014 Ag Spray Schaben Sidedresser (A56438)
2014 Ag Spray...
Kubota ZG222 (A60462)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
159118 (A60430)
159118 (A60430)
