Security & Theft best way to electrically prevent theft?
   / best way to electrically prevent theft? #11
Hmmm, sounds like you may not want to put the tractor in arms way. They want those ATVs and they will do what is needec to get them.
I wonder if you could install lojack on an atv.
   / best way to electrically prevent theft? #12
I'd put a game cam in a corner and get shots of whoever it is that comes to pick over your stuff. It may not stop them but at least you'd have evidence to take to the police.
The one other thing I have going for me is that the way the ATVs are parked (tight up against the wall), with all of the other stuff in front of them, it takes me 15 minutes USING the tractor to move a tandem axle trailer etc that is blocking their exit.
The security routine is a pain in the a-- but you get used to it.
   / best way to electrically prevent theft? #14
I bet the average locksmith could customize the ignition switch and key or you could find a compatible alternative ignition switch to install. Won't stop a professional but will addresses the one key fits all issue.
   / best way to electrically prevent theft? #15
times 2
Shane
   / best way to electrically prevent theft? #16
I've used a heavy cable and lock to secure my ATV's in a remote barn. The cable/lock is like the one's Tractor Supply uses to lash down their lawn tractors and equipment. Granted, if the thieves have the right tools they can cut the cable but it would sure help to deter and not be all that expensive.
   / best way to electrically prevent theft? #17
You could rig a pressure switch under the floor mat or seat which would trigger a very loud horn or alarm. Sure scare the daylights out of the the crooks.
I have considered a motion sensor dog bark!
   / best way to electrically prevent theft? #19
I have a main fuse that is modified not to work. Just have to switch the good fuse for the dummy. Again a pain, but hopefuly my tractor will be where I left it. I also like the trail camera idea.
   / best way to electrically prevent theft? #20
Professional alarm with battery back-up with the loudest 2 sirens you can get and flashing lights
Jim
UNUSED FUTURE MINI SKID STEER MOUNTING PLATE (A57193)
UNUSED FUTURE MINI...
UNUSED FUTURE FT-M48 48" HYD MIXING BUCKET (A57193)
UNUSED FUTURE...
2015 JOHN DEERE 1050K WH CRAWLER DOZER (A52707)
2015 JOHN DEERE...
2018 XCMG CV83PD (A53317)
2018 XCMG CV83PD...
22ft Rollback Flatbed Body with Winch (A55852)
22ft Rollback...
UNUSED JCT HYD AUGER (A57193)
UNUSED JCT HYD...
