Security & Theft best way to electrically prevent theft?
/ best way to electrically prevent theft? #41
The dealer who sold me my Kubota is now a Lojack dealer and will install it on your tractor.
I personally leave mine with the PTO lever on and the gear shift engaged. This will deter a joy rider. I also used to turn the fuel sttopcock to off but too many times I forgot and would drive a few minutes, sputter to a stop and then have to bleed it.
Dogs are no better. I've known teens, simple crooks and pro's to dispatch dogs with no trouble at all. They may stop a joyrider or vandal, but not much else.
I've settled on good insurance and quit worrying about it.
/ best way to electrically prevent theft? #42
Insurance is a must and I learned that the hard way as my first break-in in CT was not insured. :mad: I paid the stupid tax and got insurance ASAP. After the second break-in I became more interested in revenge so I use an alarm but I also use camera's. These little wireless internet camera's are cheap and easy to install and if you ever want to see a happy police officer tell him you have security camera's when they come to investigate the break in. If crooks get away with it once they will keep doing it till they get caught so I want to do what I can to make sure that they pay for stealing my stuff.
/ best way to electrically prevent theft? #43
As has been pointed out, most thieves are not well versed in tractors and want to get in and out without being noticed. Activating the safety devices on the tractor are excellent ideas, but if you want to further foil the unlikely event of having the tractor towed just park the tractor with as much bucket area on the ground as possible (backhooe and loader). The increase in friction will help, especially when it hits the tow truck lip. More importantly, on concrete it will make so much noise the they'll pass on your tractor.
/ best way to electrically prevent theft? #44
Always wondered if an 12 volt electric fence unit wired up under the hood would be effective??? MikeD74T
/ best way to electrically prevent theft? #46
I think any rollback truck could drag a 3 wheeled tractor up on it. Having the loader down would probably slow them down a bit. But where my tractor is, noise and time are not an issue. Its over a mile to the nearest house. If they come after midnight they'd have a good 6 hours before a car even went by on the highway.
However, that's also an advantage. My cabin, and tractor are accessed by a very typical and unimproved dirt driveway. The gate is an old, unmarked 16' tube gate. The cabin and tractor are not visible from the gate...or even halfway up the drive for that matter. The tractor sits in a clump of cedars near the cabin. The only give away that something is down that plain looking dirt road is the power lines.
Someone would have to know the tractor was there. But if they showed up with a rollback truck, none of the tricks I'm willing to apply would slow them down at all.
/ best way to electrically prevent theft? #48
Here's a pic i had handy.. this shows a 7610s 4wd axle ( mine is 2wd.. but it was the 1st pic I found that looked good )... see those square nubes on either side of the pivot.. those are the axle stops.. Probably look different on every model.. but they will be where the axle maximum upwards travel meets something else on the tractor.. that's where you shim the opposite side of the one with the missing wheel to keep it off the ground.
Soundguy
/ best way to electrically prevent theft? #49
Soundguy said:
No.. I'm not talking about proping it up on a piece of timber.. or on a skid.
set down in front of your tractor and find your front axle.. now find the kingpin the front axle pivots on. now find the axle stops that prevent the axle from rotating up far enough to do sheet metal and or radiator damage. Usually they are squared off sections on the front axle /kingpin carrier that have coresponding flattened sections on the axle itself.
Now remove one wheel, the axle rotates down till the hub is laying in the dirt... lets say this is the right tire/wheel removed... look on the left side.. the axle stop will most likely be touching together.. now.. lift the right side up PAST normal, and then slip in a hammer.. or some other hard object betweent he axle stops on the LEFT side, and then slowly lower the right side... you will find that the hub now dangles freely in the air.. with all weight transfere tot he single left tire due to the rigidness o fthe axle, and the axle stop, and the fact that the axle cannot rotate ont he king pin because the axle stops on the left side are held open. The tractor will be a lopside trike at that point.. will steer like a bear.. but WILL drive off on it own.. or could be winched up on a trailer.. or driven on a trailer.
I can probably post a pics of the axle stops if you can't find them.
This is how they do a clutch job .. when they split the tractor, the engine would normall slop over on the king pin.. however mechanics hammer wood wedges into both side axle stops to keep the engine centered... works fine in reverse too...
Soundguy
Well..well well.. How about them apples? Nice Soundguy! I knew you had a perfect and plausible answer... Just needed to wait and hear from you:) Good Point..
Now I know exactly what you mean. I still think the average Jo Shmo would be thief is not smart enough or have enough time to go thru all the trouble for a quick bite. Idea of blocked pivot point is good for a tractor split. If I ever have to split a tractor, I thought I'd do it on cement floor, keep the scoop loaded, lowered to the floor to keep rear housing/transmission level. Leave enough room to pull the engine section forward, remove the front weigh and balance the engine on wheeled transmission jack to move the front forward and probably keep a jack stand in front bumper in case front decided to go down.
Great response, thanks:)
/ best way to electrically prevent theft? #50
Some one mentioned a LoJac above. I looked into those when I bought my tractor and found the coverage area is very limited in the rural areas. In fact I called LoJack and their coverage in Ohio is pretty much limited to Cleveland, Columbus and the Cincinatti areas. The woman I talked to tried to continue the sale however by telling me most equipment would end up in the big cities. :rolleyes: I didn't bite.
/ best way to electrically prevent theft? #51
I agree.. the casual thief looking for something he can carry off and sell or pawn won't look twice at a 'broke down' tractor.. etc... It's the ones that want big money that scare ya...
soundguy
/ best way to electrically prevent theft? #52
repoage,
Late on this, have inquired on line, without response to camera "seller." Where did you get the internet remote cameras? Are your cameras the celphone technology?
Just had my barn and travel trailer broken into on the farm, an hour from my home.
Ed
/ best way to electrically prevent theft? #53
The only 'sure-fire' protection is insurance.
I have a Kubota that I have to leave at an isolated wooded location.
I do have insurance, but just to make it difficult for someone to steal, I did the following:
Took one of those 6' steel digging bars and drilled a hole through it.
Drilled a matching hole through the belly pan I made for the tractor.
Then I just slide the bar through the gaps in the rear wheels, going over the top of the belly pan, and padlock the bar to the belly pan.
Certainly not foolproof, but may deter some of the lazier thieves.
/ best way to electrically prevent theft? #54
I know web-cams are cheap and reliable now - How about something rigged up where the alarm system alerts you and you can record/see what's going on from a web-cam? If you are 3 minutes away you can probably catch them. Police around here seem to be a lot better at catching speeders than actual criminals (much safer and easier) so you will probably have to do the hard work youself. I commend you for standing your ground - Crime is just out of control and I hate the attitude that that is just the way it is.
/ best way to electrically prevent theft? #55
this is a old thread- but can be worth resurrecting. I don't beleive in one answers fits all situations will work. webcams, physical locks, hidden start switches, fuse removal, etc. can work on the most part.
/ best way to electrically prevent theft? #56
A simple disabling device (hidden battery switch, pulling a fuse etc) will deter the "casual" thief or crime of opportunity.
If someone has decided to steal your tractor with anything beyond a casual thought, you might as well say good bye to your tractor- they probably have prepared for any deterrent employed.
/ best way to electrically prevent theft? #57
repoage,
Ed
Surshot...go to X10.com - Security Cameras, X10 Home Security, Wireless Camera, Home Automation, Electronics and More! and take a look at all they have to offer...real inexpensive cameras that you can access online or have record what is going on...Good Luck..
/ best way to electrically prevent theft? #58
(they did say, "electrically")
/ best way to electrically prevent theft? #59
Best advice thus far. I also leave the PTO engaged and have even fooled myself on occasion. LoJack would be cool!
2004 IH 5600I Snow Plow Truck (A62679)
2004 IH 5600I Snow...
(16) Trimble True Count Clutches (A65640)
(16) Trimble True...
2020 Yanmar Diesel Engine (A65579)
2020 Yanmar Diesel...
Approximately 100 Ratchet Tie Downs (A65579)
Approximately 100...
4 Bottom Plow (A65640)
Metal Sasquatch (A65583)
Metal Sasquatch...
