Best way to cut pipe at an angle?
   / Best way to cut pipe at an angle? #1
bdog
Elite Member
Texas
John Deere 6130M
I have 2-7/8” oilfield pipe set vertically in the ground for a shed. It is already concreted in the ground. I need to cut the tops off at desired height with a 2/12 (9.5 degree) angle so I can weld the I beam for the rafter resting on top of the pipes.
I have one of those gadgets that slips over the pipe to mark a saddle, straight cut, or 45 degree cut but how do I go about making a 9.5 degree cut on the pipe?
   / Best way to cut pipe at an angle? #2
Here is a web site that has a large number of calculators and printable patterns that might help.
www.blocklayer.com
Go to "Printable Templates" then "Pipe Notching Templates"
   / Best way to cut pipe at an angle? #3
Maybe this will work.
On a scrap pipe, cut a 9.5 degree angle on a bandsaw. Then wrap it with light cardboard/stiff paper and trace the end. Cut off the part not wrapped around the pipe. Mark the high and low spots. Use this pattern to mark your standing pipes.
Bruce
   / Best way to cut pipe at an angle? #4
Pipe fitter's handbook has all the proper formulas to layout angles on pipe. And a good wraparound. There are some good videos on UT they could explain it a whole hell of a lot better than I could.🍻
   / Best way to cut pipe at an angle? #5
What tool (s) do you have to make the cut? Porta-band?
Build a jig that clamps / bolts to the pipe or to the porta-band to use as a guide
I have a 45⁰ & 22 1/2⁰ jig built so I don't have to mess with measuring / marking, etc...
Unfortunately they're in my storage unit 100+ miles away or I'd snap a pic & post it for you
   / Best way to cut pipe at an angle? #6
Porta-band and/or a Metabo. I'm making the assuption you already know how to calculate the angle and mark it.
   / Best way to cut pipe at an angle? #7
The angle cut from high side to low side is a little less than 1/2".
Not knowing the tools you have at your disposal or what the method of choice for welding is....I'd probably just eyeball it close with a sawzall....fine tune with a grinder to desired angle. Its welding, not finish carpentry. So the joint dont have to be perfect for a good weld to follow
   / Best way to cut pipe at an angle? #8
Just a piece of paper and mark out the angle using Tan tables. Then wrap it around the pipe for marking.
Thanks for the replies. I guess my issue is making the mark more than anything. I plan on making the cut with a torch. I can calculate vertically where the marks need to be. If say for example I was working with square tubing and not pipe I could make my marks and use a square to transfer them around to all sides of the square tubing. I am not sure how to do this with pipe.
As LD1 mentioned the difference is heights across the pipe is only roughly 1/2” but still if cut incorrectly that is a rather large gap to fill when welding in the overhead position. I also need to be able to balance a large heavy I beam on top of these cut posts so if the cut is wrong it is going to be very unstable while I am trying to weld it up there.
I am not sure what the “tan tables” you are referring to are Egon?
Monkey duster the block layer site is very cool and has a lot of information but the pipe notching templates I saw were all for pitting pipe to pipe. I need a simple angle cut to fit a pipe to a straight surface.
Bcp I like your idea and think something along those lines would work. This seems similar to what square1 suggested except manually marking it instead of building a jig.
   / Best way to cut pipe at an angle? #10
2-7/8 od pipe has a circumference of 9"
Draw a triangle on a piece of paper ....9" base with 1/2" height.
Cut it out, wrap it around the pipe. It will get you close enough for torch work.
Or find something round and easy to cut an angle on with a bandsaw or meiter saw. Ironically.....just finished some leftover pizza for lunch and the grated parmesan cheese container is round, plastic, and right at 3" diameter. Would make a PERFECT template. Cut on angle....slip down over pipe and mark.
Kubota B7800 4x4 Tractor (A51573)
Kubota B7800 4x4...
2017 John Deere 9620R Scraper Special Tractor (A53342)
2017 John Deere...
2024 JOHN DEERE 3039R LOT NUMBER 58 (A53084)
2024 JOHN DEERE...
Generac Generator (A51691)
Generac Generator...
8ft x 6 1/2ft Shipping Container with Side Door (A51573)
8ft x 6 1/2ft...
