Best way to cut pipe at an angle?
   / Best way to cut pipe at an angle? #21
Hold the beam in place with jack stands and follow the line it creates on the post.
   / Best way to cut pipe at an angle? #22
Tan table. Readily available on the internet.
tangent(9°) = 0.15838tangent(25°) = 0.46631tangent(41°) = 0.86929
tangent(10°) = 0.17633
draw a straight line one inch long. Add A vertical line .15838 inches high. Connect the start of line to the top of vertical line and you will have a 9 degree angle. Lay it out larger on a piece of wide tape and wrap on the pipe to be cut.
For 9.5 degrees extrapolate between 9 and ten degrees.
Thanks Egon. I had no idea what a tan table was. I'm glad you came back to explain it some. I printed out the first table that came up in my search. MAN, I wish I would have had something like this chart decades ago.
Now I can make any angle I need without guessing...Now to start saving template material.
   / Best way to cut pipe at an angle? #23
If you have a smart phone, or even a $8 scientific calculator....they have sin, cos, tan functions.
If you are building or dealing with angles (triangles)....getting good at the three functions is priceless
   / Best way to cut pipe at an angle? #24
I liked and was good at math in high school, I can still spout off the multiplication tables without thinking about the answer. But I stopped at algebra in my junior year. Spent my senior year in the shop building.
I have no idea what those 3 functions mean or what they can do.
   / Best way to cut pipe at an angle? #25
I think this is fundamentally where the education system let so many people down
They tried to teach the stuff with no context or how it can apply to the real world.
Basically, what sin, cos, and tan can do is give you the missing angles of a right triangle if you know two of the sides.
Some people use the tables, and that's fine....but if you have a calculator...you can be exact.
In the OPs example.....9.5 degree angle....you can punch into your calculator...9.5tan. (or some calculators tan9.5=)
That will give you 0.167. that is basically the ratio of rise/run in a right triangle. So it don't matter if the run is 3" or 30'....multiply that by 0.167 and you can find the rise height to equate to a 9.5 degree angle.
And you can do that with ANY angle.
Or....you can find the angle if you know the rise and run. For example....what's the angle of a 4/12 pitch truss. (Useful for setting a miter saw or cutting truss tails, etc. 4÷12 = .333 so you can use the calculator or tan tables and see what angle = .333. which happens to be 18.4 degrees.
You can do that with any pitch roof. Or any thing else you want to know the angle of.
Since tan is just the relationship of rise/run (or opposite and adjacent sides of the angle your are working with)
Sin and cosine are the relationships of the other two sides. Sin is the opposite side and the hypotenuse. Cosine is the adjacent side and hypotenuse.
Then comes the old Pythagorean theorem. A²+B²=C² this is derived from the law of cosines. Lots open people learned this in school but didn't retain the info because they lacked the real world connection and how they would ever apply it.
But let's say you have a 30' truss with a 4/12 pitch. How long are the roof panels you need to order for the building. Can you figure it without waiting til the trusses are on site and measuring them?
I use this stuff daily. But I build alot of things with both wood and metal. Anytime you have to deal with angles....the knowledge of sin, cosine, and tangent are priceless
   / Best way to cut pipe at an angle? #26
No problems. The tan was often used to make angles when drafting without the use of a protractor. Quick and easy. Of course, if six figure log tables got involved it could be tedious!
magnetic stick on sheets may work well for templates.
   / Best way to cut pipe at an angle? #27
That was me too. Algebra? I told the teacher I figured I needed this crap a) if I was going to be an engineer or b) an Algebra teacher- and I intended to be neither one. I still whip through numbers in my head to the amazement of my other half. We've built many specialized things with specific angles. Solar greenhouses, trapezoidal buildings, etc. etc. etc. She's the calculator and spreadsheet queen and fortunately for me- she's good at it. With out her it's measure, measure, cut, recut...Hopefully for the OP, he's a great out of position welder up in the air. I get good at it again, once I'm near the end of the project!
   / Best way to cut pipe at an angle? #28
it's never too late to learn new skills. i entered the work force a few years before the internet age and before the pc was a household appliance. everyone on here who is my age or older learned to use a pc well after they were in school. For some it may have been necessary for a job, but for a lot it was a desire to learn it for their own usage. the same is true with any sort of math. if you want to learn something, you can. it's even easier now because you have every possible online resource at your fingertips.
back to the original topic... i just googled and came across this:
looks like the same thing i showed above. mostly just projection of lines - very little math needed.
   / Best way to cut pipe at an angle? #29
I know what those functions are because I sort of learned them... but I hear you. The trick to getting through arithmetic class is to sit at the back of the room drawing goofy cartoon characters and counting how many times the teacher says, "pay attention".
Math teachers all show you how to do the problems in class anyway. Math isn't thinking, it's doing...same as welding. When it comes test time, just do it like they showed in class.
rScotty
   / Best way to cut pipe at an angle? #30
I liked math in school, it was a good thing, because my 6th grade teacher, Mr. Hershberger, loved to give us pages full of multiplication and long division problems. I hated them at first, but eventually started enjoying doing them. The other kids thought I was crazy. After that, geometry and trigonometry were pretty much a breeze. I still like solving math solutions to practical problems just like this thread involves. I even liked algebra and still occasionally use it to solve some problems. I'm even working on how to manually solve square roots, that has a lot of practical applications.
But when I got to college and into calculus class, I really struggled to make it through the first semester. I just never "got" calculus, I read several books on it, even one just recently on the history of calculus, but it just never soaked into my brain.
3000 Gallon Black Poly Water Tank (A49461)
3000 Gallon Black...
2020 CHEVROLET Z71 TEXAS EDITION TRUCK (A51406)
2020 CHEVROLET Z71...
2015 Manitou MLT840-115 PS 4WD Telehandler (A50657)
2015 Manitou...
UNUSED Clear Corrugated Polycarbonate Roof Panels (A50860)
UNUSED Clear...
66in Light Material Bucket Skid Steer Connection (A51039)
66in Light...
1985 Ford C-800 Grumman Fire Truck (A50860)
1985 Ford C-800...
