Best way to clear unwanted trees from pasture
   / Best way to clear unwanted trees from pasture #121
Before you go purchase equipment might check someone like this out. Caterpiller Skid Steer 299 xhp Mulcher For Rent - farm & garden - by owner - sale
Caterpiller Skid Steer 299 xhp Mulcher For Rent - $475 (all around east Tennessee)
My trees are Bradford pears and the roots need to come out of the ground.
   / Best way to clear unwanted trees from pasture #123
I don't have time to read 11 pages right now, so hopefully this hasn't been covered. I think your M7060 with a FEL should push 5-6 inch trees over without too much effort. I do it all the time with my M7040.
avid from Jax
   / Best way to clear unwanted trees from pasture #124
avid from Jax
I would recommend a tree puller. I know if the tree can be pushed over with your tractor, you can pull it with a good puller: tree puller for front end loader - Image Search
Intimidator | Tree & Post Puller | Danuser
I bought a Kubota M7060HD12 today with a rotary cutter and a root grapple. I pick it up in three weeks. Let the games begin!
   / Best way to clear unwanted trees from pasture #127
Be sure to post pictures, and enjoy your new machine! (Not necessarily in that order. ;) )
   / Best way to clear unwanted trees from pasture #128
That sounds like lots of fun. You'll need that much tractor with horses anyway, so might as well see how it does on removing trees and improving the pasture. Speaking of trees, horses, and pastures..... I can't think of any reason not to have trees in a horse pasture. In fact, I think that horses might just agree. So If it were my horse pasture I'd probably take out the smaller trees and leave the larger. You can always remove trees, but replacing them is harder to do.
Enjoy the tractor,
rScotty
   / Best way to clear unwanted trees from pasture #129
"I can't think of any reason not to have trees in a horse pasture."
Trees that are an invasive speices that are bountiful seed producers.
Trees that produce thorns that puncture tractor tires.
Trees that obstruct the ability to spray and fertilize.
Trees that limit the ability to hay the field.
Trees that procuce toxic or harmful materials.
   / Best way to clear unwanted trees from pasture #130
Having a few clumps of trees here and there isn't a bad thing. I wouldn't strip the entire property if there are some desirable trees to retain. However, I am very familiar with what the OP is facing. If it is like other fields that grow up around here the first things to show up are cedars, locust and wild cherry. None of those should be left in a pasture field.
2008 Ford Crown Victoria Sedan (A55853)
2008 Ford Crown...
2014 MACK GU713 WATER TRUCK (A54756)
2014 MACK GU713...
Ford 8340 (A53317)
Ford 8340 (A53317)
VERMEER D9X13 SERIES II HORIZONTAL DRILL (A52707)
VERMEER D9X13...
2016 Ford Taurus Sedan (A55853)
2016 Ford Taurus...
Frontier AV50H Root Rake Grapple (A53317)
Frontier AV50H...
