Chains Best type of chains to get?
   / Best type of chains to get? #11
before i paid a tractor dealer 1200 for a set of chains, I would look at a set of semi-truck chains and cut to fit. I did this for my 4X4 pickup, oh yes, we have traction.
I see you're out here in WA - so where did you get your semi-truck chains?
   / Best type of chains to get? #13
BABAC Traction Products - Forestry & Heavy Equipment Tire Chains
try the above link, it has logging chains. The "net" type with carbides are about as good a traction as you're gonna get but you pay for it too.
re the truck chains - aren't these just ladder type?? ok for forward/reverse traction but not so much for lateral. You can also go witha duo grip and modify ie add chain, yourself.
Wow - those are a bit extreme although I'm sure the loggers around here probably do use them in the wet mountains. I think the duo-grip/combo should suit my needs. Now to find the best price...
2007 Hyster S30FT 3,000lb. LP Forklift (A60460)
2007 Hyster S30FT...
Groundsmaster 3500-D madel 30839 (A56859)
Groundsmaster...
2005 Sterling Acterra Tender Truck (A56438)
2005 Sterling...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2003 Big Tex 10PI...
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A55853)
2004 Pierce Tilt...
