Oil & Fuel Best spray multipurpose lubricant
   / Best spray multipurpose lubricant #21
Someone should sell kits of straws AND extra rattle can nozzles.
   / Best spray multipurpose lubricant #22
I'm partial to PB myself, but it depends on the job. WD is fine for squeaky door hinges, etc. and is less messy.
Curiously, does anyone sell those little plastic straws separately? It's always the first thing that gets lost.
I don't know but I take them off any empty cans I trash.
   / Best spray multipurpose lubricant #23
   / Best spray multipurpose lubricant #24
The spray paint can ones I save are always plugged!
   / Best spray multipurpose lubricant #25
Zep 45 has been my go to.
   / Best spray multipurpose lubricant #27
Put them in a baby food size jar with a little laquer thinner.
Let the jar sit for a while and shake,..... maybe repeat.
I clean spray can nozzles like this all the time.
   / Best spray multipurpose lubricant #28
I always take the nozzles off the paint cans and spray carb cleaner thru them after use.
   / Best spray multipurpose lubricant #29
I think pretty much anything works. It's when you use nothing, that you have a problem. People have trouble getting out unlubricated fasteners, then go all overboard with NEVER SEIZE. A little dab of any old grease would have prevented the problem.
Don't know about grease even though it would help. I use never seize on everything and never had issues taking something apart. Holds up to heat better than grease also.
   / Best spray multipurpose lubricant #30
After use I've been pulling the tips off and spraying through them with air from my compressor seems to work I've been using this method for a no. of years.
1991 FREUHAUF 40FT BELLY DUMP TRAILER (A57880)
1991 FREUHAUF 40FT...
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
2012 BIG TEX PIPE TRAILER (A55745)
2012 BIG TEX PIPE...
2015 Volvo VNL 64T (A55315)
2015 Volvo VNL 64T...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2010 Ford F150 Single Cab Pickup Truck (A55973)
2010 Ford F150...
