Best, smallest, tractor with bucket and rear hoe?
   / Best, smallest, tractor with bucket and rear hoe?
Thanks all, very good suggestions, I think you guys are probably right that a SCUT is probably overkill. My propery which minus the house is probably at MOST 3/4 acre, is very uneven, hilly, and has lots of obstacles, like PVC pipes sticking out of the ground for my leak field, well pump head, garden beds, etc. Currently I have a 4x4 ATV, and I use the ATV to pull around a 10 cubic foot Sears cart that I usually use to move dirt, rocks, etc. Then in the winter (I live in northern Jersey), I use the ATV with a 48" plow to remove the snow off my driveway which is about a 100' paved level driveway. The ATV with the plow has no problem going through about a foot of snow so it works good. The issue I have is that I am going to most likely need to get rid of the ATV because it's my father's and he wants it back for his house.
So because I am sick of pushing my walk behind mower up and down my hilly uneven property, I thought that I should get a ride on mower, but if I was going to get a ride on, I should try and get something that I could use for also plowing my driveway of snow in the winter, and something that could handle pulling a 10-20 cubic yard trailer full of rocks, dirt, etc. around my yard and up slopes. My front yard looks like a huge mound with grass on it as I have a raised septic system so the huge mound is my entire front yard and it's a pain to cut the grass becasue of pushing the lawn mower up one side of the mound and down the other.
My backyard slopes down away from my house and I plan on building a retaining wall and backfilling it to level off my back yard. When this happens, I will have lots of dirt delivered and dumped near my front yard that I will have to move to the backyard. This is where a Loader would be very useful. Besides this, I supposed I could use a loader to plow my driveway in the winter as well. A rear end hoe would be nice but I would probably need to use it a couple of times for stumps, etc. A few miles away there is a rental shop with all this kind of equipment, so I could always rent a small backhoe for these few instances I suppose. So maybe I would be better suited with a nice riding mower that is strong enough to handle pulling carts of dirt, and plowing my driveway? what do you guys think, any recommendations?
I was looking at some of the Sears and Home Depot John Deere ride on mowers. They are okay but looks sort of cheap and I think that my hilly, bumpy, uneven yard might hurt their frames, trannys after a while but I'm not sure what these machines can really handle as I have never owned one. I was checking out the Kubota BX1500 with the front loader, now that looks nice, but you are still talking about 10K for that machine with a loader and mower. Plus I don't know something like that would compare to a Sears ride on mower in terms of cutting around obstacles and making sharp turns.
   / Best, smallest, tractor with bucket and rear hoe? #43
Get the BX24 TLB to do the work you discribed you'll love it. Anything bigger would be a total waist of money in my opinion. I'm not sure I would be able to justify $16,000 for a BX24 TLB with the lot size you discribed. But if you can offord it you won't regret it.
I wouldn't spend the extra $1500.00 for the BX mower, not for one acre of land. You'd be better off with an inexpensive Sears riding mower for around $900.00.
Jim
   / Best, smallest, tractor with bucket and rear hoe? #44
Jim
   / Best, smallest, tractor with bucket and rear hoe? #45
get the bx1500, loader, mower, rear blade for snow, 48" box blade for dirt, rent the hoe as needed , give dad back his ATV, cart and blade, then enjoy
   / Best, smallest, tractor with bucket and rear hoe? #46
what's the BX1500 with mower and loader cost?
If you also were to buy out of state do you need to pay any sales tax on it?
How does the BX1500 compare to the BX23/24 with the exception of the backhoe? Are there considerable differences in the tractor, etc?
2022 Ligchine Spiderscreed Concrete Screed (A59228)
2022 Ligchine...
2023 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A56858)
2023 GMC Sierra...
Volvo EC220EL (A60462)
2001 INTERNATIONAL 4900 WATER TRUCK (A58214)
2001 INTERNATIONAL...
pressure washer, and trailer (A56859)
pressure washer...
CASE IH MX220 MAGNUM TRACTOR (A57192)
CASE IH MX220...
