Question about tractor choice
/ Question about tractor choice #1
jca1
Roanoke Rapids NC
NA
Hi everyone, my name is Chris and I live in the big city of Roanoke Rapids NC. I'm in need of some advice or maybe just others opinions but in any case I hope I can find some help here. My wife and I have a little over 1 acre with mostly grass but we have plans to expand our gardening to cover much of our property over the next few years.
Currently we have a Gravely PM44Z commercial Zero turn mower but my wife will not learn to operate it, but she wants to cut grass. I'm currently looking for a heavy duty lawn mower that can perform more functions than just mowing. Having the ability to use a towable tiller, small disc, rake, etc would be great so right now I have my eye on a JD318 with front and rear hydro lines. The price for a JD318 in great shape seems to hoover right around $2000-$2500 and is within my price range.
Just today I saw a NH TC-18 with less than 900 hours with a belly mower for $5000 and a Kubota BX1850 with belly mower for $5000 with less than 600 hours.
This got me thinking, maybe I should stop focusing on large lawn mowers like the 318 and start focusing on small tractors? I can afford $5000 but I wouldn't really call it in my price range.
Have any of you been down this road?
/ Question about tractor choice #2
A BX sized machine would be nice around your property. You will gain a 3 point hitch and 4WD. You can buy durable implements for it instead of the cheaper stuff that is sold for garden tractors. The 3PH implements are way easier to use than a pull type. When you want to turn or back up you just pick it up.
Would you suggest one of these over the other: 2006 Kubota BX1850, less than 500 hours with belly mower $5000 or 1999 NH TC-18 650 hours with belly mower $5000? I'm guessing the newer Kubota is the better deal but I have zero knowledge about either of these machines so maybe the 99' NH is a better tractor, I really don't know.
/ Question about tractor choice #4
You didn"t mention if the used tractors were from an individual or dealer. You can always make an offer. Or go to tractor house.com and see how similar used ones are priced. I do think in the long run you will be happier with a small tractor with the uses you outlined. I don't know I would want to give up the z turn for mowing! I would vote for the kubota due to the year. Also, checkout Barlow Equpment online they 6 or 7 BX 1850's for sale that would be worth pricing out. Best of luck in your search.
They are both private party, different owners. Best I can tell the price of each is much lower than average. I think the NH may be 2wd while the Kubota is 4wd, both have turf tires. The Kubota is a single family machine the NH is a two owner. The current owner of the NH claims to have rebuilt the mower deck with new spindles and bearings. The plan is to keep the Gravely right now.
/ Question about tractor choice #6
It's so easy to spend other people's money..:D.......but while you are at it I'd suggest getting something like the Bx1850 with a front loader (FEL) as well as the 3pt hitch. If you and the wife are going to be doing much gardening it really helps to have something for lifting and moving dirt, bags of fertilizer, rocks etc. However, I got along for 50 years without such a tool and did huge gardens....thanks to good health, a strong back and a weak mind.:D and Oh....did I mention ....no money, but lots of kids.
I'd def. want to add a FEL at some point but right now I'd love some help deciding between the two tractors. It seems to be a no brainer to go with the Kubota since it's a newer machine and 4wd but if the NewHolland is a better machine then I'd go that way. The Kubota seems to be a much better deal for the $. $5000 for a 06' BX1850 in 4wd with belly mower? It seems like $8000 is the going price for something like that.
/ Question about tractor choice #8
Sounds like a good deal on the Bx. They are quality machines. What dealers do you have close? Don't want to be driving 3hrs.for the occasional part or service.
That's an excellent question I hadn't thought of and it looks like there is a dealer not far from me in Enfield NC.
/ Question about tractor choice #10
They are actually somewhat different machines even though they have similar power and weight. The TC18 is a "compact" style tractor, meaning it has larger tires, it's longer, has a more robust 3 pt hitch, etc. The BX is a "subcompact", so it's considerably shorter and lower to the ground. Still has way more capability than your typical "garden tractor", but it's downsized even more so it would take up less space when parked, would handle hills and side slopes better, etc. If you did a test run on each machine, you'd immediately see the difference. Kubota does make some other models more comparable to the TC18.
Either machine could be a good choice, depending on its condition, but I'd say the BX might make a lot of sense for your property and situation. Your wife would probably find it's easy to use for mowing. Even my bride will mow with it once in a while, and that's saying something for it. Even so, ours has been reliable and done plenty of serious work since 2005.
I would say to check the condition of either before buying. You're right about the pricing. In fact, the price on the BX is so low, I'd be wary of what might be wrong with it. Maybe it's just someone really anxious to sell, but then again... get out your magnifying glass and really know what you're buying before writing any checks.
/ Question about tractor choice #11
I would probably go with the BX but that is not seeing both tractors. I am not sure but I think the 50 sereis BXs had a problem with a abrupt stop. I think there were updates to the hydro to correct it. It is something you may want to research.
/ Question about tractor choice #12
318 is old junk. go with cab bx3030. all the bells and whistles. hot air for the winter cold air for the summer. lots of heads turning when young jogging ladies walk bye
/ Question about tractor choice #13
If a 318 is junk, a cab "bx3030" is junk. If you can turn heads in that. How come a JD 7230R can barely turn any heads? What kind of world are you living in. I guess the heads are being turned from the young ladies are because your driving on the wrong side of the street, and swerving all over the place?
/ Question about tractor choice #14
A 318 is better than a bx3030 that doesn't exist! The 318 is a excellent mower and is by far not junk!!!! Get the **** off this forum and go back playing club penguin. Noodles you are just a troll and I bet you dont even own a toy tractor let alone a real one! (Dont care if I get banned for it cause it was ******* worth it!!!!!! This troll is a ***)
/ Question about tractor choice #15
Welcome, JD6400NZ. Of course you're right about those old 318's... they have been great machines for lots of folks. TBN has been remarkably free of the typical internet stupidity over the years, but sometimes you have to set up an "ignore" filter.
/ Question about tractor choice #16
Unless you are going to perform all of your own maintenance and service check with the closest dealers of whatever brand you plan to purchase. Dealer support is critical in the event of mishaps, breakdowns, parts, and also attachments, etc. Look for reviews of the dealers, but take them with a grain of salt.
/ Question about tractor choice #18
For what you're describing, the BX sounds about perfect. I would actually really like to have something in that size for some of the more typical chores I have that really don't require the bigger machines I own.
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59905)
2018 INTERNATIONAL...
2020 Broyhill Load and Pack TD3.6 Mini Articulated Garbage Truck (A59230)
2020 Broyhill Load...
2023 VOLVO ECR25 ELECTRIC EXCAVATOR (A60429)
2023 VOLVO ECR25...
2012 Ram 2500 4x4 Crew Cab Pickup Truck (A59230)
2012 Ram 2500 4x4...
2012 Ford Transit Connect Cargo Van (A59230)
2012 Ford Transit...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
