Best, smallest, tractor with bucket and rear hoe?
   / Best, smallest, tractor with bucket and rear hoe? #31
KentT, you will never hear me suggest a PowerTrac is a bad solution, I'm one of the few conventional tractor owners who also owns an articulated tractor, and who has had a couple PTs out at my property. I'm not sure that the "mini hoe" is up to the capabilities of a Sub-Cut back hoe, and I consider the finish mowing quality of the PT 422 and PT 425 to both be marginal (which is the main reason I purchased a Ventrac instead of a Power Trac), however for an "all around" tractor, it is very difficult to find a machine that is as well suited to the small land owner than a PT.
   / Best, smallest, tractor with bucket and rear hoe? #32
   / Best, smallest, tractor with bucket and rear hoe? #33
Kubota BX24. There still may be very good deals on the discontinued BX23 out there also.
The BX23 and/or BX24 will give you an ample FEL, 6' digging depth BH and when outfitted w/a MMM it will give you a lawn mower quality finish cut. And all these implements can be mounted/dismounted without any tools in minutes......
Now when I take off my orange colored glasses I would recommend putting your seat in the seat(s) of the Kubota BX23/BX24 & the Massey GC2310 as well as the TZ & others and enjoy the process. Go with the one that fits and cranks your tractor /forums/images/graemlins/grin.gif
Volfandt
   / Best, smallest, tractor with bucket and rear hoe? #34
Volfandt
   / Best, smallest, tractor with bucket and rear hoe? #35
I think the key to the answer is, as Bob mentioned above, the property size: 1 acre.
Since the original poster asked about cost, the $16K+ price of a BX24 or comparable small TLB may come as a shock. Or course, that includes the MMM. /forums/images/graemlins/grin.gif
For one acre, I doubt that I would want anything larger than a BX size machine.
I'm surpirsed the "do you really need a backhoe?" question did not come up! /forums/images/graemlins/blush.gif (well I guess it did... /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif )
If spending a large chunk of money is not an issue, my advice would be to go with nothing larger than the BX size machine. Get the backhoe, you will love having one. The loader will you love even more over the years.
The small machines like the BX do cut grass quite nice...not that the slightly larger ones don't. But with only an acre of property, the small subcut really is the best match in my limited experience.
Can't really comment on the small power trac, although I do know they are machines loved by those who own them... /forums/images/graemlins/smile.gif
   / Best, smallest, tractor with bucket and rear hoe? #36
   / Best, smallest, tractor with bucket and rear hoe? #37
<font color="blue"> Uh guys, just for reference, this guy has a 1 acre property. ....for 1 acre he could do most of the chores with a garden tractor </font>
I read a lot of "what size tractor for this many acres". To me it should be what size tractor for the jobs you want to do. (And of course, "what can you afford?) I have a Wheelhorse 310-8 garden tractor. It's a very good mowing machine, a fair snow plow machine and a light wagon hauler. My 1.5 acres has rocks that weigh more than the Wheelhorse I am moving, areas I plan to level out and other jobs that will require three point implements. I'm keeping the Wheelhorse to mow with, but I bought a Ford 1310 for doing the real work. Someday I would love to get something with a small BH. /forums/images/graemlins/grin.gif
   / Best, smallest, tractor with bucket and rear hoe? #38
   / Best, smallest, tractor with bucket and rear hoe? #39
I agree that for that property, you may want to just have someone remove the stumps and do some clearing. None of the suggestions is inexpensive, and if you're not going to be doing a lot of subsequent heavy work, that money will be ill spent.
If you think you may buy a larger property later, it makes more sense. Stumping is not as easy as some would have you think. Pine tree stumps, with their long tap roots, require a lot of time to get out of the ground with a compact tractor backhoe. For most folks, just having them ground is sufficient unless one wants to plant a lot where the stumps are, this should be fine.
If you have plenty of money, and don't mind doing so, buying any of the scuts, or a cut such as the CK20 I have should serve you well, but the smaller tractor will have less digging power and clearance than a CUT.
John
   / Best, smallest, tractor with bucket and rear hoe? #40
John
2015 LOAD TRAIL 24+6 GOOSENECK TRAILER (A58214)
2015 LOAD TRAIL...
2005 Chevrolet C4500 Altec Bucket Truck (A56858)
2005 Chevrolet...
2015 Peterbilt Dump Truck (A55973)
2015 Peterbilt...
2017 Ram 1500 Pickup Truck, V6, 4X4, Automatic Transmission, 212,570 Miles (A56438)
2017 Ram 1500...
JCB 220XLC-4F EXCAVATOR (A60429)
JCB 220XLC-4F...
2015 CAT 950M Wheel Loader (A55272)
2015 CAT 950M...
