Best Oil for Kohler Command V -Twins
   / Best Oil for Kohler Command V -Twins #21
duplicate
   / Best Oil for Kohler Command V -Twins #22
Curious how many "go against the factory recommended lubricants" and choose oils based on their own bias.
Most threads would say "stick with the factory , they know".
Oil preference is so personal.
   / Best Oil for Kohler Command V -Twins #23
Kohler recommends 10w30 in all their engines except the larger 38-40 hp engines which require 20w50 oil. I have a piece of equipment that says use only 10w30 and the engine manufacturer doesn't even supply that weight of oil The chooses from the engine manufacturer are 30w or 5w30 synthetic blend.
   / Best Oil for Kohler Command V -Twins #24
I run 5-40 Rotella T5 in everything including my zero turn with a 25 horse Kowalski. Never an issue. I do pull the shroud yearly and blow out the crap. Air cooled engines need cooling air....
700 hours on the Kowalski, no issues other than a valve adjustment. Incidently, the Generac extra capacity spin on oil filters fit the Kowalsaki, I use them, change the oil every fall.
   / Best Oil for Kohler Command V -Twins #25
Amsoil small engine 10w30 is all you will need. As well as amsoil 20w50 hydro fluid for the tranny.
New/Unused AGT Industrial SDA-140T Track Loader (A57453)
New/Unused AGT...
2000 GMC C7500 SINGLE AXLE VOCATIONAL TRUCK (A56129)
2000 GMC C7500...
2014 Trail King TK50LP Equipment Trailer (A57453)
2014 Trail King...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
2023 Chevrolet Tahoe SUV (A56859)
2023 Chevrolet...
New/Unused 10ft X 20ft Single Garage Metal Shed (A57454)
New/Unused 10ft X...
