Best deal on Quick attach
/ Best deal on Quick attach #1
halfbean
East Texas
I have a Ford 4630 with a 7309 loader. I want to convert it to a skid steer quick attach on the front.
What would be the best way to do this? Is there a certain manufacturer that is the best or one to avoid?
Thanks
Hal
/ Best deal on Quick attach #2
I have a Kubota M6800 with 1002 loader.Want to do the same thing and go quick attach.
/ Best deal on Quick attach #3
You guys might be better off posting in your respective brand owner forums. I've got a ATI QA on my Kioti, but I have no idea what I paid for it. Nor do I know if ATI makes one for your loaders. All I can say is that my ATI QA is really heavy duty...
/ Best deal on Quick attach #4
Check with your Kubota dealer. I added a SSQA last year and the genuine Kubota part was a lot less expensive than the aftermarket. It was less than $450
/ Best deal on Quick attach #5
From my dealer in Fredricksburg, VA 1 year ago:
I think you have a Kubota LA1001 or LA1002 front loader -- if so Kubota # M1802 is a 2 lever quick attach bracket designed for it.
Cost is $606.00 including freight cost -- plus tax
/ Best deal on Quick attach #6
Thanks
Hal
I bought the both parts for the quick attach from Northern Tool. The one that goes onto my bucket, I cut my bucket to get a flat surface and welded it on myself. Then for the part that goes onto the loader, I drew out a bracket on cardboard, cut it out to make sure it fitted, then took it to Lews Welding in Tyler to fabricate it.
In the last couple of weeks, I've had my grapple on, pallet forks and right now the hay spear is on it. Funny, but I rarely use the bucket for anything. The grapple is on the tractor 90 percent of the time.
/ Best deal on Quick attach #7
Cheapest route would be titian don't know quality of their SSQA but am happy with my pallet forks and 3pt receiver hitch
/ Best deal on Quick attach #9
My neighbor put the Titan conversion on his Case JX55, no issues.
/ Best deal on Quick attach #10
Titan..
/ Best deal on Quick attach #12
That is the other way around.
That's to adapt a loader that has quick attach to use 3PT implements.
100 Gallon Plastic Tank (A65640)
100 Gallon Plastic...
2023 Wolverine R-Max 2 1000XTR (A62679)
2023 Wolverine...
1995 Landoll 55 Ton Trailer (A60352)
1995 Landoll 55...
John Deere 1530 Tractor (A66285)
John Deere 1530...
Rotary 15,000lb. 4-Post Auto Lift (A64556)
Rotary 15,000lb...
1984 Cab Over K100 Big Cam 350 (A62613)
1984 Cab Over K100...
